Hi, I've seen AUdio Nirvana 2.8 cabinets for 12" speakers. Do you know if they are "empty" cabinets or have some diaphragm inside?
Thansk all Ziocalepino |
#2 |
frugal-phile(tm)
They are big empty boxes (if you ignore damping material) with holes in the front (3/4" deep ports), and one size fits all.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
I built one of those. It is a box with a reinforcement close to the center of the box. It is one piece that looks like a square edge 8.
Alfredo |
#4 |
Many thanks. Is it possible to see few pictures of inside?
#5 |
#6 |
Wow ALfredo great answer! Many thanks! Few more quesitons if you can:
- distance of centre of tho holes from top of cabinet - diameter of bass reflex hole And, of course, how do these drivers sound? Again many thanks! PS: are you of italian origin? |
#7 |
29 1/4 inch from bottom of speaker to the center of the driver.
13 1/2 to the center of 6 inch port. If you buy the drivers from commonsense audio they will include the cabinet plans. How do the sound? I like them a lot for Jazz and vocals. Do not prefer them for loud Rock, too much shout. In the past few days I have been playing with a minidsp 2x4 and I have tamed them for Rock. I use a different source on my preamp to select the unfiltered versus the minidsp. Italian? 5th generation Caribbean Corsican. Alfredo |
#8 |
Ok undestood.
I know if you buy drivers commonsense audio gives you plans too. The fact is that I have to build these cabinets for a friend who bought used drivers and he has no plans. But with your indications I think I've all in my hands. The project is very similar to Fostex FE206 Bass Reflex that I've built last year. Dimensions are greater but the concept seems the same. I use Tang Band speakers and Lowther too, expecially these last. I've built Bicor 200 and Acousta 116 cabinets for Lowther. If you want to share some tips I'll appreciate. Thanks for all |
#9 |
As you can see from the pictures, I used R30 insulation and stapled it with a pneumatic stapler, it compresses the insulation nicely. I also used pocket holes and glue to build the box. It is much quicker this way as I did not need to use clamps. I then filled the pocket holes with glue and dowel. Making the box is very easy, veneering is more work. I used the glue/hot iron method. Plenty of wood on one veneer side and the box sides. Two coats each. Once dry, use a hot iron to bond the veneer to the box.
Good luck. Alfredo |
#10 |
To assembly my cabinets I use buscuit jointer glue and clamps. I do not know "pocket holes" technique.
To veneer I use classic yellow glue. I think it will be not so simply with a so big enclosure... |
| Audio Nirvana Super 3 | GMark | Full Range | 8 | 11th May 2011 06:03 PM |
| audio nirvana super8 cabinets decision | neazoi | Full Range | 13 | 21st July 2010 01:32 AM |
| FS/FT Audio Nirvana Super 12 Cast Frame drivers in custom cabinets | vaughn | Swap Meet | 12 | 5th April 2010 01:51 PM |
| Audio Nirvana | autheim | Multi-Way | 6 | 21st November 2006 11:46 PM |
| Audio Nirvana - Where Is It? How Do We Get There? | Bas Horneman | Everything Else | 9 | 25th January 2006 02:05 AM |
| Page generated in 0.10178 seconds (78.57% PHP - 21.43% MySQL) with 10 queries |
