Audio Nirvana 2.8 cabinets
Old 10th September 2011, 11:45 AM   #21
ziocalepino is offline ziocalepino  Italy
Another question. It seems to me that you do not join together the two pieces of veneer before gluing on table. Is it correct?
Old 12th September 2011, 01:15 PM   #22
Hi Alfredo, during last week end I've tried few solutions to glue two veneer sheets one close to other. I've tried to glue them separately keeping care tu set the second perfectly attached to the first, but after ironing I've obtained a 2 or 3 mm gap between them.
So i've tried to keep them together using paper adhesive band, as well as I'm doing when using contact glue, but the result was the same: 2-3 mm gap.
Can you help me please?
Many thanks
Old 12th September 2011, 03:35 PM   #23
avincenty is offline avincenty  United States
For the large speaker cabinet i used single piece veneer. When i have done veneering with multiple pieces i have done a couple of things.
One, as pictured on the link, is to leave an overlap between the two veneer pieces. Iron carefully as close to the intersection (without bonding the overlapp), then using a sharp blade cut a new edge for both at the same time, remove the excess, align the new edgess so they butt against each other and finally iron the edge.
Second, butt the two edges together and place blue masking tape over the edge (before applying the glue). After you apply the glue and let dry, start ironing the seam first so that it puuls the veneer towards the center of the seam. Then you can iron from the seam out. You always need to leave a small overlapp on all sides that need to be trimmed later.
Good luck
Alfredo
Old 12th September 2011, 05:12 PM   #24
Well now I have to try! First solution seems to be easier... seems!!! Another way could be give veneer to my supplier who has a special tool to sew them together on the rear side with a very thin plastic wire, but I suspect that ironing this wire melts and tho pieces move.
Thanks you are very polite!
Old 13th September 2011, 07:09 AM   #25
Alfredo, as suspected the solution to use pre-sewn veneer is not suitable because the nylon wire used melts during ironing.
I'll try your first solution after having well understood how to do. I'll let you know develops.
Have a nice day
Ziocalepino
Audio Nirvana 2.8 cabinetsHide this!Advertise here!
audio nirvana super8 cabinets decision neazoi Full Range 23 4th February 2013 07:44 PM
Audio Nirvana Super 3 GMark Full Range 8 11th May 2011 06:03 PM
FS/FT Audio Nirvana Super 12 Cast Frame drivers in custom cabinets vaughn Swap Meet 12 5th April 2010 01:51 PM
Audio Nirvana Andy9485 Multi-Way 6 21st November 2006 11:46 PM
Audio Nirvana - Where Is It? How Do We Get There? Bas Horneman Everything Else 9 25th January 2006 02:05 AM
