Ohm Walsh 2 need advice
Old 4th September 2011, 04:54 PM   #1
Sk8Ter is offline Sk8Ter  United States
Default Ohm Walsh 2 need advice
Looking for some "ideas" on how to make the ohm f have more extended more robust bottom end
Inside the cabinet is the original thick cotton material that extends around the cabinet .. in the middle uses broken up pieces of this cotton material that is only on the very top(closest to the driver) and nothing underneath...
Ideas Please
Lawrence
Old 4th September 2011, 05:51 PM   #2
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
"new input terminals with gold-plated binding posts and 12 gauge OFC interal wire. This allows for deeper bass and wider dispersion of the high treble"
I read it at the Ohm site
Please note that I'm not a cable or Super Solid Brass fan ,but optimum conductivity and bottle -neck avoidance should be performed by every DIYer.
Cotton can be replaced by some lighter ( air permeable ) material ,such as Dacron , not allowed to move inside the cabinet , just attach it by glueing it to the internals . maybe they put it in the middle to overcome the probably stationary wave due to the high height /base ratio .
Ohm Walsh 2 need adviceHide this!Advertise here!
THE PENCIL: inspired by Ohm Micro Walsh Tall Juspur Multi-Way 97 12th May 2014 11:10 PM
Ohm Walsh 2 - can i cut these pool strainers off? ark Multi-Way 14 13th November 2011 05:30 AM
FS: Ohm Walsh F drivers/cabs Zero Cool Swap Meet 14 11th June 2010 10:30 PM
I need replacement tweeter suggestions for OHM Walsh 4XO speaker Jack Torrance Full Range 1 13th March 2008 07:30 PM
Copyright ©1999-2017 diyAudio
