Small Full Range driver selection - Page 3 - diyAudio
Old 5th September 2011, 07:32 AM   #21
Abelma is offline Abelma  Belgium
Do you use any BSC filter or equalization on those two driver projects?
Originally Posted by vinylkid58 View Post
Pretty sure my 7's are not Gen3, but they have the P10 treatment.
Yes to the second part.
A7.
jeff
Old 5th September 2011, 08:03 AM   #22
frugal-phile(tm)
planet10's Avatar
Originally Posted by Abelma View Post
Jeff, what kind of enclosure is that for the FX120? Is there plans available?
Jeff's own Fonken-like enclosure (for the FE127, i have heard him opine that it is a bit small for FX120.
Out larger box, i have plans for it (we didn't choose the colour scheme on this one, the client did, to my mind the veneer would work better on a smaller bpx, and the red spots clash)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th September 2011, 04:19 PM   #23
Bob Brines's Avatar
Originally Posted by planet10 View Post
I was considering W4-1879, but i find it kinda ugly, so on recommendations of a couple people i got W5-1611.
dave
I have a pair of these, but I haven't spent much time with them. They are a drop-in for the RS 40-1354a, but sound much better even without expensive break-in. One interesting feature is a hole around 6-7kH, so sibilance is not a problem.
Bob
Old 6th September 2011, 04:54 AM   #24
vinylkid58's Avatar
A slightly larger Fonken, with more vent area, approx. 80% of the FE127 Sd. Basically, an experiment to see how far the FE127 could be pushed to produce a little more bass. On paper, the FX120 looked looked like it would work in this box also, so curiosity took over.
PM me if you're interested in the drawings. Just be aware that this box was meant for the FE127, and would probably benefit from a slight revision for the FX120. 15mm BB instead of 12mm for starters.
No.
jeff
Old 6th September 2011, 03:17 PM   #25
Hi Bob,
How you compare the TB with the Alpair7, and/or if you know also the Fostex FX120in your opinion?
Its high price is justified?
Looking for the best low freq performance, the TB seems the one?
Thx
Bob
Old 6th September 2011, 04:43 PM   #26
chrisb is offline chrisb  Canada
The Gen3 Alpair 7 driver seems it has a better sensitivity response, flatter, that would say that the new genereation is less agressive for people that found a little bright on mid top?
Thx
FWIW since we've been listening to Alpair7 for over a year now, they were obviously not Gen3, but I certainly can't recall anyone commenting on over-bright top end or other issues with upper midrange - certainly not the case for some of the Fostex drivers in this size range (i.e. FE126E ).
as to Jeff's enclosure pictured - as he noted this particular pair was actually built for FE127E, and a dedicated enclosure of this format for "optimal" LF performance on the FX120 would probably need some revisiting
... so, not as easy at it sounds, this letting go thing
Old 6th September 2011, 07:34 PM   #27
frugal-phile(tm)
planet10's Avatar
For best low frequency performance without sacrificing the critical mid-top, you can't beat separate woofers.
dave
Old 6th September 2011, 09:04 PM   #28
ghw is offline ghw  United States
If you don't want a BSC or other EQ circuit between the amp and the woofer, you have a few options, assuming you do not want your speaker to sound like a 6dB shelving low-cut filter). These are listed in order of decreasing sensibility.
1) Put the BSC at line level, before the amplifier. This could be done actively, e.g. in the feedback loop of an opamp, or passively, e.g. between a buffer like the B1 or a low-impedance source and the input of your amplifier.
2) Design a speaker to be mounted on or in a wall. This eliminates the baffle step as an issue.
3) Design the dimensions of your speaker around a wide-range driver with a conspicuous 6dB shelf at some frequency, and then choose the dimensions of your baffle around that shelf. This seems like a brutal design constraint.
You appear to be opting for either third approach (find a driver with the shelf built in) or a speaker with the low frequencies shelved down 6dB. Neither option avoids equalization of the speaker. The former approach introduces a very rigid design constraint that is unlikely to be met and the latter does terrible injury to your signal (presumably music).
Dave appears to have the best approach (use a separate woofer for the low end). If you start with a relatively high-excursion, low-efficiency mid-top, like the Scan-Speak 10f, you can then choose a woofer 6dB more sensitive and cross at the baffle step center-point to take care of BSC. Again, this could be done at line-level to avoid EQ networks in between your amps and drivers.
George
Old 7th September 2011, 07:44 AM   #29
Reading in other post about the FX120, a owner did not like him with transistor amplifier? Only when he used a tube amplifier he liked. why this could be?
wich enclosure for fostex's FX120
Originally Posted by chrisb View Post
well he can snatch this one now for his collection
of course he might well have (misplaced) one or two pictures of this already - wanna try and sift through that one time?
While not as pronounced as with the FE127E (or the new FF125WK) the FX 120 will definitely have that signature midrange presence/dynamics that I've not found in Alpair7.
Dave - you should try to fully break-in the WKs for a session with all 3
Old 7th September 2011, 07:46 AM   #30
Thank you for your opinion George.
But I will stick with the idea of one driver in this project.
George
Small Full Range LousSpeaker with Jordan Driver scottjr Full Range 3 4th February 2011 07:37 AM
Full range driver & enclosure selection help CrookedChris Full Range 36 26th August 2009 11:59 PM
support for small full range Artmaster Full Range 8 20th November 2006 09:59 AM
full range low cost and small size driver availability in Mumbai cutesound Multi-Way 1 14th October 2006 04:16 PM
Multimedia Satellites, Open Baffle?, Full Range? Driver Selection Help Required ozynigma Multi-Way 32 7th May 2004 04:29 PM
Copyright 1999-2017 diyAudio
