Old 1st September 2011, 05:05 AM   #1
Default Help a newb pick a first project...
Hows it goin guys? First off, I'm not a complete newb to audio or box building but I want to try and take my skills to the next level by building something a little (maybe alot) more complicated. Here are a few boxes I've built before, mostly ported car audio for teenagers that like the boom...
I have been looking around at some full range speakers and just dont know where to start. I have an Onkyo TX-SR508 A/V receiver that will power whatever I build for now then later down the line I'd like to do some sort of DIY amplifier.
Anyways, to start off with I was going to buy a pair of the Fostex FE103En and build the back loaded horn that they recommend in the manual.
I litterally have no reason for choosing that driver other than price and the fact that there is a box design in the manual. Thats how lost I am when it comes to home audio like this.
I just wanted to make sure that this was an acceptable first project for a newb. I have never heard a quality setup before in my life so I'm sure whatever comes out of these will sound great to me.
I'd like suggestion on what to do differently, maybe different drivers or enclosures. I'll post up some pics of whatever I end up with. I have set myself a spending limit of $100 for the speakers.
Thanks for your time guys...
Old 1st September 2011, 07:25 AM   #2
karmik is offline karmik  Italy
karmik's Avatar
Send a message via ICQ to karmik Send a message via AIM to karmik Send a message via MSN to karmik Send a message via Yahoo to karmik
Hi and welcome
Very nice job on the routing of the speaker baffle holes in those subs.
I actually have _less_ builds under my belt than you, but they're both of the kind you wish to build now so i'll provide my feedback :P
Fostex is an excellent choice as a first home audio system, the two speakers i bought both sound very good imho (FE167 and FF85-WK).
I think you could give a shot at the fancier boxes like
I didn't build any of these ( i plan to build a uFonken soon and probably a Half Chili-Chang for my FE167) but these are the design and design sites you see constantly flying around on the forum, and the people behind them are VERY knowledgeable.
EDIT:
I'm not sure how the other members of the forum feel about metal screws in the structure of the boxes, but as far as my minuscule experience goes, in home audio that's a big no no. I see many people here on the forum gluing directly panel to panel, with just weight and pressure keeping the pieces in place while the glue dries. Personally, i use wood plugs to give strength to the whole structure.
The only place i use any kind of metal fixture is the back panel, where i use brass plugs to house heavy duty bolt screws to keep the back panel in place (to make the speaker serviceable). To somewhat smooth out vibrations, i use teflon rings around the bolt and usually glue the brass plug in place with vynil glue to make them as deaf and as coherent to the structure as possible.
Also, you might want to use thick stuff like 18-20 mm panels
Hope i was of help
I Void Warranties
Old 1st September 2011, 04:25 PM   #3
chrisb is offline chrisb  Canada
toylo:
a few peso's worth of almost free advice:
ignore Fostex factory "recommended" enclosures - for any given driver there are numerous DIY / free designs widely available that easily outperform them (I've even built a few of them myself)
the FE103E is a sweet little driver, but rather limited in terms of attainable SPL and bass response in any enclosure design, unless assisted by woofer(s)
select a driver / enclosure design based on your room / musical taste/listening habits - even the best of "full-range/ wide band" designs are not for everyone
regardless of selected design there are probably more viewpoints on construction techniques / materials for loudspeakers than you can count on both hands -
keep the change
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 1st September 2011, 05:15 PM   #4
karmik's Avatar
Originally Posted by chrisb View Post
toylo:
Ahh if only i'd asked the same question before building them! I could be sitting close to a uFonken and a Half-Chili right now if i did This year's build will be my last fostex reference design :P
I Void Warranties
Old 1st September 2011, 05:29 PM   #5
hey, it took us at least 4 factory designs to confirm that to our own ears - and while it's hard for me to believe after the experience, some folks are quite content with them
Old 2nd September 2011, 05:23 AM   #6
Hi and welcome
Thanks for the complient!
The Spawn and the Solo103 both look like they would be fun. The frugal horn looks a little too complicated for me now, but maybe next time.
Where can I buy the FE107? I seem to be having a hard time finding some of these drivers I see mentioned around the forum.
I would, but I have no idea what would make one speaker or enclosure better than another in a certain room. I was just going to build something and listen to it, then try something else. I figure even something that sounds "bad" to an audiophile is going to sound amazing to me because I don't have the the experience they do.
The room will most likely be the living room which is about 20 foot long and 14 wide with one side open to a kitchen and dining room. The speakers will only be able to be about 8 feet apart due to doors. I sit about 12 feet from the speakers, leaving another 8 foot to the wall behind me. I will be using these for listening to rock, classic rock and the occasional low volume movie. Would rather have them more oriented toward the music though.
Old 2nd September 2011, 06:04 AM   #7
frugal-phile(tm)
planet10's Avatar
FE107 has not been available for a long time.
One thing not mentioned is the drivers synergy with your amplifier.The Fostex are notorious for revileing the warts in your amplification. You might find yourself building your new amp sooner than you expected.
Something that has better synergy with your current amplifier (usually beause of lower efficiency pushing your amp into an area where it sounds better) might be a better 1st project, With your budget, abd sticking with drivers im familiar with perhaps(the broadly similar) CSS EL70 or the new Mark Audio CHP70.3. EL70 has been around longer so there are more proven boxes (here are some), goes lower, and is a bit flatter up top. CHP on the other hand has 3rd generation Mark Audio technology, (the EL70 is 2nd generation tech) so may have somewhat more finesse, and the purposely suppressed top octaves give a more classical FR character.
There is also the CHR70.3 -- the metal cone variant, i mention it last a smy personal preference is for the paper cones.
All of the 3 above run <$80/pr.
The recent skyrocketing of the price of neopdymium has pushed some nice drivers out of your price range. Tangband for instance. Some of their drivers have close to dounbled in price. And even thou they have come back down a bit (likely due to not selling at the higher prices) they are still high.
Another new driver that holds potential is the Fostex FF125wk. It may or may not have the FExxxEn family penchant for showing warts but early audions (in boxes not designed got them) are promising. Its smaller sibling, the FF85wk, is definitly a keeper, but with very limited bass.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 2nd September 2011, 10:43 AM   #8
karmik's Avatar
dave
Damn, i'm sorry. I haven't checked before posting.
Would the 103 be enough for a room that size?
I Void Warranties
Old 2nd September 2011, 02:10 PM   #9
zman01 is offline zman01  Bangladesh
toylocost,
Dave has mentioned a number of driver choices - given your room size a dual driver design would be probably better - less pressure on the drivers and higher potential SPL. In this regard the Micro Towers can be a design you can look into. Some members have done recent builds and are happy. Folks have built with EL70, and IIRC the new CHP 70 also performs well in that cabinet. The higher ohms of the CHP70 gen 2 should allow for parallel wiring too.
http://homepage.mac.com/tlinespeaker...aps-150909.pdf
The build is also relatively simple.
Old 2nd September 2011, 08:34 PM   #10
frugal-phile(tm)
planet10's Avatar
When we looked at the FE103e we decided that since FE127 was only a couple bucks more we'd work with that... once the 7k peak was dealt with FE193 had no advantages.
Today i would tend to look at the FF1265wk instead of FE103En
dave
Newb looking for some expert advice for his first project (5.1 speakers) tim_programmer Multi-Way 3 19th July 2008 05:42 AM
Help me pick an enclosure project for EVs kvk Full Range 21 4th April 2008 05:53 PM
First Time Newb: Help me pick woofers and tweeters (needs to be shallow) nobb Car Audio 0 19th April 2007 01:20 AM
need help to pick new project busterno1 Multi-Way 4 17th June 2006 05:24 AM
newb with a project already. primopyro Introductions 5 27th October 2005 01:16 AM
Page generated in 0.15763 seconds (84.62% PHP - 15.38% MySQL) with 10 queries
