Old 29th August 2011, 03:37 PM   #1
Location: Mississippi, where good music comes from, or used to anyway
Default CHBW-70 and CHP-70 mixed in a Lotus^2 cabinet
Just for a little background, I can build just about anything out of wood or MDF. I am however, no expert in configuring speakers or designing cabinets. I will have a little spare change very soon and I can swing two pairs of the 70 series.
My question.... Would it be feasible to use both the CHBW-70 and CHP-70 to build each of my Lotus^2 cabinets or would this severely screw up the final build? I'm just thinking that it may give a little more low end on the final build.
I plan to build the cabinets as the instructions have them described with the CHP-70 forward facing and the CHBW-70 facing inward.
Old 29th August 2011, 06:07 PM   #2
frugal-phile(tm)
planet10's Avatar
An interesting question.
CHP & CHBW have slightly different tuning. Scott will be the one to give a definitive answer, but my gut (based on my much smaller boxes (i expect Scott's to be a bit more tolerant)), is thet 2 CHP or 2 CHBW would work fine, but thet mixing could give somewhat poorer results as the 2 drivers fight a bit on the bottom.
In an "optimum" small box, you get a couple more hertz with the BW (this isn't an EL70, which has about 10 Hz on CHP), and its high frequency shelf is about 5 dB lower than the CHP.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
chr-70 vs. chp-70? Sonogasm Full Range 10 26th November 2011 05:02 PM
CHBW-70 Markaudio's new bass-wide markaudio Markaudio 12 23rd September 2011 02:46 AM
chp-70 coniston or lotus cabinet ? clk230 Full Range 14 13th August 2011 03:17 PM
CHR-70, CHP-70, Alpair 7 Desktops - Japan markaudio Full Range 4 1st February 2010 01:42 AM
Page generated in 0.07635 seconds (68.88% PHP - 31.12% MySQL) with 10 queries
