Fostex FF225WK + FF85WK together? - Page 3 - diyAudio
Old 1st September 2011, 10:37 PM   #21
Greg B is offline Greg B  United States
there is some precedence for this approach in the old SDX7/alpair5 combo.
Even more precedent than that... I 'stole' the idea from an old ~1970 pair of Wharfedales I had. 2 ways with a crossover near 1kHz were common in the 60's AFAIK. The original AR-1 used an Altec 755 as a 'tweeter'.
This is really the kind of project where you'd want to try a few different crossover points and decide for yourself. Dave reports plenty of dynamic range with a 350hz crossover, and I do like crossing at the baffle step if possible. OTOH, years ago I crossed an FF125K to a 10" bass driver at about that zone, and it clearly could not keep up with the woofer, at least with a 1st order highpass. Obviously a steeper and/or active crossover will solve that, but introduces its own problems.
Old 2nd September 2011, 12:45 AM   #22
frugal-phile(tm)
planet10's Avatar
Originally Posted by chazdrumzalot View Post
SDX7/alpair5 combo. Crossover points anywhere from 500hz to 1.5khz were suggested
If it has the minimal treatment SDX7 rolls off fairly smoothly at 1.4-1.5 kHz. If stock it is a rollercoaster above 500 Hz.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 6th November 2011, 06:56 AM   #23
norman bates's Avatar
FF225wk.
I know it ain't cheap, but what about adding a fostex supertweet ?
Like the ft96h ?
http://www.fostexinternational.com/d...f/ft96hrev.pdf
Not sure but a 2uF should be a pole near 10khz.
They recommend 1uF (20khz pole, -3db@20khz, -9db@10khz). This seems too high for me.
Norman
Old 6th November 2011, 09:11 AM   #24
frugal-phile(tm)
planet10's Avatar
Steve the shawdow (the guy that came up with Metronome) has just done up (with Toppy's help) an FF225wk Met + FT17. He found a 1 uF worked right afetr trying a whack of variations.
Last post in the thread (as of now)
audio-talk :: View topic - Axiom 401 in a Metronome Cabinet
A more efficient tweeter would need a smaller cap.
dave
Old 7th November 2011, 03:41 PM   #25
chrisb is offline chrisb  Canada
Originally Posted by norman bates View Post
FF225wk.
Like the ft96h ?
Norman
if the extreme extension and sensitivity of this class of horn super tweeter is not essential, something like the 85WK allows a lot more flexibility in terms of playing with XO corner and slopes, for slightly more than 1/4 the cost of the FT96H
on hiatus
Swap: Fostex T825 for a higher efficiency top tweeter by Fostex, Coral etc anubisgrau Swap Meet 1 22nd July 2012 06:12 PM
FS: 2 super tweeters Fostex T90A + 2 attenuators Fostex AT50H merlin el mago Swap Meet 7 29th October 2010 09:14 PM
fostex 208ez and fostex ft17 h good kombo? almightybozo Full Range 1 24th September 2010 06:00 PM
FOSTEX FE126 in Fostex BR Enclosure nafunga Full Range 3 29th July 2008 07:21 PM
WTB: a pair of Visaton B200 or Fostex F108ES or Fostex FE126e or Jordan JS92S Rafal Swap Meet 0 10th November 2006 01:35 PM
Copyright 1999-2017 diyAudio
