may have jumped in at the deep in here... - Page 2 - diyAudio
Old 28th August 2011, 10:21 PM   #11
revboden's Avatar
You won't need a big box, those drivers should be fine in 8L each.
http://www.jbl.com/resources/Brands/...20friendly.pdf
Old 28th August 2011, 10:26 PM   #12
karmik is offline karmik  Italy
karmik's Avatar
Send a message via ICQ to karmik Send a message via AIM to karmik Send a message via MSN to karmik Send a message via Yahoo to karmik
Originally Posted by stahlm004443 View Post
thankyou very much, that is a big help.
this is sort of a first try kind of thing, i will probably end up making a better one with bigger and better woofers and what not at some point.
so MDF or PLY? im probably only going to use 10mm maybe 12mm because weight is a big factor in this build.
Plywood every day of the week. Ew, i still can't understand why people use MDF. I don't find it easier to work with at all. But it might just be me :P
12mm is really really thin 15-18mm would be much easier to work. Anything less than that and each drill hole, each cut you make you risk to lift bits of wood around the area you're working on (i'm assuming you're not a master woodcrafter).
Personally, i never go below 20mm :P (First project was 30mm )
I Void Warranties
Old 28th August 2011, 10:37 PM   #13
Cool, love it when they publish the specs. Every thing you need for the design in that PDF.
Generic Signature
Old 29th August 2011, 12:05 PM   #14
thanks everyone, been a massive massive help, hopefully my things turn up soon so i can play around with it all and let you know how it goes.
so the woofers are not the best option then, if i change the woofers, could i still use the crossovers and tweets that come in the package?
if so what 6.5" woofers does any one recomend?
thanks
matt
Old 29th August 2011, 12:37 PM   #15
In defense of MDF, try making a panel door out of ply and then giving it a paint finish, or a box with a quarter round profile on the edges and then finish it in a piano gloss. Real wood has it's problems too, make a bunch of cupboard doors out of it and you will need to replace some of them a year or even two later through splitting and warping because it's not very stable. MDF overcomes these problems but is very dense and lacks strength for shelving etc, it sags with time. It's horses for courses, I'd make a portable boom box out of exterior grade 18 mm ply.
Old 30th August 2011, 05:46 PM   #16
so ive got a charger that i use to charge rc car batterys, its an inteligent multi charger, it says i can charge Pb cells, is that sealed lead acid?
here is the charger
Imax b6
Old 30th August 2011, 06:15 PM   #17
chrisb is offline chrisb  Canada
agreed - MDF definitely has its place, even in speaker building ( i.e. jigs and templates ) but piano gloss finish on any material takes tons of time
on hiatus
Old 31st August 2011, 12:58 AM   #18
Im planning to make the same thing. This is the battery charger im looking at. Im planing on using 3in and 2in fullrange drivers.
Old 31st August 2011, 08:10 AM   #19
karmik's Avatar
I think johnnyfive82's charger is the right one. The one OP posted earlier in the thread is an RC Car charger and thus suited for lithium ion/lithium polymer batteries.
I Void Warranties
Old 31st August 2011, 11:47 AM   #20
But I says it can charge Pb battery's. And Pb is sealed lead acid is it not?
Deep Listening Roushon Analogue Source 10 7th January 2016 03:46 AM
I'm in pretty deep! SixFoFalcon Introductions 2 28th December 2007 05:49 PM
Deep Stereo waltube Music 3 2nd February 2007 10:22 PM
Deep HT Sub With a Twist bjackson Subwoofers 15 8th August 2006 07:41 PM
Now Thats Deep jwatts Subwoofers 17 3rd February 2005 03:23 AM
Copyright 1999-2017 diyAudio
