Taking the Air Cavity/pre-chamber to the next level... - Page 3 - diyAudio
Old 29th September 2011, 07:15 PM   #21
frugal-phile(tm)
planet10's Avatar
Once the blocks were in it worked really well with A7 and EL70, and is no longer suited for FE126. Valiant has a deeper air cavity and is wider internally, so by decreasing the volume of the air cavity we have made the horn incompatible with FE126. This same treatment is easily doable in all of the new Woden rear mouth horns as long as you plan ahead.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th September 2011, 06:53 AM   #22
ArtsyAllen's Avatar
Question Is Olique the same as Isometric
Originally Posted by planet10 View Post
Allen,
Is it possible to get a couple olique photos?
dave
Are these "olique" photos? I remember Isometric from drafting class in school a while back... ... is that the same as olique? This difuser is hard to get the light right. Here are three diferent lighting arrangements of this difuser in an Isometric composition. Let me know if you prefer a diferent composition .
Old 30th September 2011, 07:01 AM   #23
frugal-phile(tm)
planet10's Avatar
Yes, thanx.
dave
Old 30th September 2011, 12:21 PM   #24
mondogenerator's Avatar
nice diffusors, whether oblique or isometric, the new pics certainly illustrate the depth. Time to get my mitre out
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 30th September 2011, 10:08 PM   #25
dave
Thanks for the info dave. At the very least it would mean that my upcoming Valiant would have an "upgrade path" open if ever I find in the future that the A7s are more to my tastes.
Old 1st October 2011, 03:24 PM   #26
Pingpong balls work good too
Old 1st October 2011, 07:10 PM   #27
yeah...maybe if the were filled with poly resin
Old 14th September 2012, 05:09 PM   #28
bqc is offline bqc  United States
EL70eN was installed and the "issue" we were having that we were using as a benchmark had dissapeared. The new Alpair 7.3 was installed (sans extra magnet as that was quicker than cutting a hole in the damping to accomodate it) and worked superbly.
dave
What was the issue that this mod fixed? Can you describe the sonic improvement?
Old 14th September 2012, 06:23 PM   #29
frugal-phile(tm)
planet10's Avatar
I can't recall what the issue was. Maybe that we ran out of salmon (cans of salmon were originally used to reduce the air cavity)
dave
Old 14th September 2012, 07:08 PM   #30
chrisb is online now chrisb  Canada
was not the "issue" that as our bastardization of Scott's Maeshowe (originally designed for the Mark Audio drivers) for use with the Fostex FE126 significantly increased the volume of driver chamber - beyond that in which the Alpairs( or EL70) would be at their best? IIRC they sounded quite bloated and colored without reduction of the chamber volume
the staggered blocks make a lot more sense than canned fish (or water chestnuts )
on hiatus
Taking my KT88 SE E-linear amp to the next level (long) JoshK Tubes / Valves 5 1st June 2011 03:23 PM
New Line Pre-Amp taking Shape Bonsai Analog Line Level 2 21st December 2010 05:12 AM
HELP ! how to make an air chamber of 25L tcat Everything Else 3 3rd January 2009 05:45 AM
base cavity? anonymoose Multi-Way 6 11th June 2005 05:49 AM
coupled cavity sub maquiniana_phil Subwoofers 3 19th May 2005 06:27 PM
Copyright 1999-2017 diyAudio
