Taking the Air Cavity/pre-chamber to the next level...
Old 15th September 2012, 12:26 AM   #31
gafhenderson is offline gafhenderson  United Kingdom
so is the theory behind this about reducing high frequency transfer into the horn itself?
Old 15th September 2012, 01:01 AM   #32
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
The theory is that the volume of the air cabity, the exit to the horn, and the driver parameters controls the cut-off frequency going into the horn, Larger = lower.
The goal for a smooth hand-off is that the distance from the start of the horn to where the horn output merges with the output of the front of the driver is an odd number of half-wavelengths of the cut-off frequency.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th September 2012, 03:47 AM   #33
FozzZ is offline FozzZ  Canada
Is there a particular frequency range that the diffusor should be built for or is the air volume the primary factor in the design.
From a symetry point of view, would a slat diffusor work just as well or possibly better than the 2D diffusor? Theoretically, 2D diffusors disperse sound in a verticle and horizontal direction. Where slat diffusors only scatter sound in one direction. Could this be used to your advantage here?
There is enough space available behind the main air chamber in the Maeshowe to allow for a fully adjustable air cavity. Where you could allow the diffusor to move forward and back changing the air volume behind the driver. It could also allow you to make the diffusor a little deeper if a lower tunning of the diffusor is required.
Is any of this worth trying?
Old 28th September 2012, 03:54 AM   #34
frugal-phile(tm)
planet10's Avatar
Yes.
dave
Old 28th September 2012, 04:03 AM   #35
I planed to, just making sure I'm not wasting time.
But what frequencies would you suggest I try to control with the diffusor? Is ther a particular range that is troublesome for the EL70 and this design? The reason I'm asking is because I don't want to build the diffusor so deep as to cause issues with the low frequencies reproduction. I know the wave forms are much to long to be effected on their own, but mid frequencies often reinforce lower frequencies.
Old 28th September 2012, 07:09 AM   #36
frugal-phile(tm)
planet10's Avatar
The acoustic cut-off of the horn will be on the order of 250 Hz, so it is frequencies above that that will come into play.
dave
Taking the Air Cavity/pre-chamber to the next level...Hide this!Advertise here!
Taking my KT88 SE E-linear amp to the next level (long) JoshK Tubes / Valves 5 1st June 2011 04:23 PM
New Line Pre-Amp taking Shape Bonsai Analog Line Level 2 21st December 2010 06:12 AM
HELP ! how to make an air chamber of 25L tcat Everything Else 3 3rd January 2009 06:45 AM
base cavity? anonymoose Multi-Way 6 11th June 2005 06:49 AM
coupled cavity sub maquiniana_phil Subwoofers 3 19th May 2005 07:27 PM
Copyright ©1999-2017 diyAudio
