Just done some quick Win ISD modelling of this 8" subwoofer: Aurasound NS8-385-4A 8" Woofer: Madisound Speaker Store It appears to be ideally suited to compact low efficiency 4th or 6th order bandpasses. (For compact subwoofers low efficiency is required for decent bass extension.) 4th order : 3L front tuned to 90Hz. 8L rear sealed. This has a flat section rising 2dB from 60Hz to 115Hz. High pass roll-off : -3db : 150Hz, -6dB : 170Hz, -12dB : 215Hz. Low pass roll-off : -3db : 47Hz, -6dB : 41Hz, -12dB : 31Hz. (note actual levels for the LP are 2dB lower due to flat section rise, i.e. the low pass roll-off is referenced to -2dB@63Hz.) 6th order : 3L front tuned to 90Hz. 12L rear tuned to 27Hz. This has a flat section rising 3dB from 44Hz to 115Hz. High pass roll-off : -3db : 150Hz, -6dB : 170Hz, -12dB : 215Hz. Low pass roll-off : -3db : 33Hz, -6dB : 28Hz, -12dB : 21Hz. (note actual levels for the LP are 3dB lower due to flat section rise, i.e. the low pass roll-off is referenced to -3dB@44Hz) The 6th order puts out substantially more output than the 4th in the 20Hz to 50Hz region, 6th is a very impressive curve. However I must stress for bandpasses acuracy is everything, I cannot guarantee the driver specs or WinISD's modelling accuracy. The results should be checked in other programs. Parameters used are : Fs - 40Hz, Vas - 17L, Qts - 0.34. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow Last edited by sreten; 15th August 2011 at 04:59 PM. |
#2 |
nice sim, i wonder how the group delay would compare? Id guess the 6th is well over 30ms, in fact id be shocked if the 4th was under 20ms. Would be interesting to compare the 6th with max flat vented. Ive never found much advantage to 6th order bp using winisd compared to regular vented. But then i only have the beta version. The 4th bp is, however, more interesting, at least to my eyes, and truly compact. Venting 12L at 27Hz would give me nightmares! Nifty though
Im starting to think its gone beyond a hobby, a wardrobe full of drivers instead of clothes... Last edited by mondogenerator; 15th August 2011 at 06:15 PM. |
#3 | |
Some good points, most of which are inevitable. Your right 12L @ 27Hz is a nightmare, PRs/ABRs are probably the only sensible practical solution. The driver itself in a sealed say 6L box would be great for max output, but it must be used as a bass only unit in a 3way, or with a FR unit. TBH for $20 the latter could be compeletely its forte. rgds, sretyenm/.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#4 | |
Like this woofers specs by the way, looks like a real bargain. Last edited by MisterTwister; 16th August 2011 at 03:39 AM. |
#5 |
agreed paired with a suitably cheap fr it would make a good sub, either sbb4, bp4 or bp6. I just have an perhaps illogical hatred toward the bp6s ive heard, the bass thud always seems like an echo of the actual transient. Ive got a pair of poly 2inchers from some aldi pc speakers that could work though.
Im starting to think its gone beyond a hobby, a wardrobe full of drivers instead of clothes... |
#6 |
with those woofers going so cheap i wonder what a 2 or 4 driver isobaric bp sub would be worth trying.
#7 | |
Due to the high driver mass, 54g, stiff suspension, hence high Fs, and consequently very low Vas, isobaric is utterly pointless. A 2 or 4 driver normal box is sensible, and would ease the venting, it would also be possible to build in force cancelling mode easily. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow Last edited by sreten; 17th August 2011 at 02:32 AM. |
#8 |
Some info on normal box loading, its very compact. Nevertheless this driver is ideal for a first order series c/o at the baffle step frequency to a typical 3" good FR like the B3S or NS3. Not bad for $20. Throw in a FR notch filter and you get a killer small budget speaker. rgds, sreten. I like the one with the best -6dB (and -10dB) point.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow Last edited by sreten; 17th August 2011 at 03:18 AM. |
#9 |
And for those that are into group delay here are the plots, not surprisingly the red curve is the best of the vented, as it has the most smoothly bending bass roll off, and hence the best transient response. rgds, sreten.
#10 |
ah yes.... Vas is a bit low for it to be practical. teach me for thinking aloud....or not thinking aloud lol
group delay isnt too bad either so bandpass would be reasonable, compared to other drivers of similar size. hmmmm the pink response DOES look interesting
Im starting to think its gone beyond a hobby, a wardrobe full of drivers instead of clothes... Last edited by mondogenerator; 17th August 2011 at 04:46 AM. |
| I have two 3" FR drivers for use in FAST - which should I use | tuxedocivic | Full Range | 8 | 26th June 2011 01:42 AM |
| compact OB sub - suitable 8-10" drivers? | Bill poster | Subwoofers | 22 | 12th May 2011 08:33 PM |
| WTB: 269-469 ("1$ Parts Express") drivers, or other really cheap FR drivers. | Spasticteapot | Swap Meet | 1 | 5th November 2006 03:31 PM |
| WTB FR drivers for "bigger is better" speakers. | Spasticteapot | Swap Meet | 2 | 28th October 2006 08:08 PM |
| 12" driver with big Xmax,low Fs, & high efficiency? | WolfmanX | Multi-Way | 18 | 26th November 2002 11:10 PM |
| Page generated in 0.14951 seconds (82.08% PHP - 17.92% MySQL) with 11 queries |
