I have recently started planning my first speaker diy and was looking for some advice on which drivers to use for my project.
I plan on mounting 2 full range speakers in my wall with 2 subs. My room while a bit oddly shaped has an empty cold room behind the drywall that is perfect from what I've read for a backless setup. I had origonally planned to make use alpine 10.2s but that was when I was going to be building an enclosure. Below are the ~ dimensions of the room with speaker placement. I would like to spend about 500$-750(max) on the drivers. Any advice or links would be awesome.
#2 |
Just to clairfy, I am looking for recommendations for a full range + woofer speaker setup for an infinite baffle setup.
#3 |
frugal-phile(tm)
Mounted on the wall, they will need a back, if just to create a seal.
Wall mounting requires a slightly different attention to detail on the bottom end as the wall becomes the baffle. I am currently working on a left-right-centre wall-mount "sound-bar" for under a TV using Alpair6p (+ helper woofers) dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 |
I was planning on building the wall joists for support. With the room behind closed would I still need to seal them if the back room is a closed room?
Do you think the alpair 10.2s would work well with an infinite baffle setup like above? Most IB information I can find that's resent points to car audio speakers and woofers instead of the ones I see people commonly praising as good FR speakers. |
#5 | |
The system Dave is talking about is intended to extend little if any more off the wall than the depth of flat screen and its mounting bracket. edit: while not stated, the above assumes the large rectangle is a TV screen, not a window BTW Dave, did you see my query regarding the installation method?
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi Last edited by chrisb; 9th August 2011 at 07:59 PM. Reason: elaborate on assumption |
#6 | |
frugal-phile(tm)
dave
| Going Backless | SlunkBoy | Full Range | 10 | 21st October 2009 06:42 AM |
| To wall mount or not? | bikelectro | Multi-Way | 2 | 16th April 2009 01:42 PM |
| zaph slimline wall mount | blue934 | Multi-Way | 4 | 17th May 2007 02:05 PM |
| Wall mounted "fullrange" speakers | BjoernBach | Multi-Way | 3 | 27th February 2007 06:07 AM |
| in-wall/on-wall speaker? (axiom w-22 clone?) | Scott_fx | Multi-Way | 0 | 22nd February 2007 02:08 AM |
| Page generated in 0.09789 seconds (74.95% PHP - 25.05% MySQL) with 10 queries |
