Since I will be moving in the next month or two into my parent’s house (divorce) I moved my stereo there. The room will not accommodate H-frames but the Beta 12 open baffles (with supertweeters) will fit nicely by the fireplace (pics to come). They will be replacing an old pair of AR92s.
Rather than dismantle the H-frames I will keep them intact and leave in storage until I move again in hopes I will be able to use them. I have an extra Jamo 15” buyout woofer that works well in my son’s open baffle and thought I’d build an OB to enhance the bass (necessary with the Beta 12’s on OB). The woofer sims OK (I compared to the venerable Alpha 15 as a benchmark). Then I tried the inexpensive GRS 15” paper woofer and it simmed really well. Basically it's a 24" baffle that will be about a foot from the side and rear wall and i simmed it as being 4" from the floor. GRS 15PF-8 15" Paper Cone Foam Surround Woofer I will probably use the 15” Jamo buyout but for your convenience I wanted to post my sim for anyone considering an OB woofer. Also, since I only have room for one, does anyone have any comments on using just one woofer (powered by a sub amp) as a subwoofer compared to using a more traditional woofer in a box? I hope I can achieve reasonable volume levels (no need to rock the house but a satisfying low end would be nice at reasonable volume). Thanks, Zilla |
#2 |
I will build it and let you know how this turns out. Wood already cut.
#3 |
Have you considered this driver?
Goldwood GW-215/4 15" OEM Woofer 4 Ohm Run the simulation, I think it will go lower and is a bit more efficient. Low Re means a smaller coil for a passive crossover. Martin |
#4 |
Yup, that one sims quite nicely and with a bit of a bump before rolling off. -3 @ 26hz.
Unfortunately, the driver i have on hand sims the worst. But at least others might be able to do something similar and get better results. If the driver i have now is not up to par sonically it's nice to know alternatives are relatively cheap. This 'subwoofer' will really be very slim on the floor. I hope it works out nicely! Thanks Martin, i appreciate your suggestion. PS... the sim shows how higher qts drivers have the advantage on OB. Typically these drivers are less expensive too. Last edited by Godzilla; 9th August 2011 at 08:27 PM. |
| Ok forget boxed ESLs | Borat | Planars & Exotics | 3 | 4th December 2009 08:32 AM |
| OB bass equalisation for boxed sub's. | ashok | Subwoofers | 4 | 24th April 2009 03:15 PM |
| FS Boxed plate amp, OB use | 2litre | Swap Meet | 0 | 3rd January 2009 11:37 PM |
| UCD 180 boxed | Bgt | Class D | 11 | 24th July 2005 09:45 AM |
| UCD400 boxed | Bgt | Class D | 14 | 9th July 2005 06:39 PM |
| Page generated in 0.08570 seconds (79.17% PHP - 20.83% MySQL) with 11 queries |
