gem or garbage?
i acquired 2 recently, unlikely ill ever use them as im kind of a bookshelf+ sub, boombox or car audio kinda guy. they're about 15 " each, and pretty stiff/springy/resonant when tapping the cone if anyone wants them id be happy to sell or trade for anything i can use or do i put them in the trash
#2 |
Here's something I found:
ID'ing old Magnavox console components "Here is what I do know: This unit was one of Magnavox's first solid-state versions ca. 1965. It was about 6 feet long with removable sliding wooden panels on the top. The control unit and record-changer were in the right-hand side. An album storage bin and speaker selector switch were located in the left-had side The amp was 50 watts and was remotely located in the bottom of the cabinet. The woofers are 15" in diameter and say, 'Magnavox 581515-1 719' " probably not full range then. But if you search for the part number you'll find other reports of similar consoles. Can you measure them?
Then again, what do I know?
#3 |
i have no way to measure them.
#4 |
The Magnets look very small and do not look to be ALNICO but the over all build quality looks good. I wouldn't expect them to handle a lot of power but the light weight paper cones should give decent mid range performance. They would most likel make an excellent guitar speaker. Just guessing though.
PASSIONN |
#5 |
Speakerholic
What makes you think they are not alnico? They come from the right era when the surround was part of the cone. They might be a good candidate for an OB in the garage or WHY.
#6 |
Don't recall numbers anymore, but they sure look like what I used in early 48" high x 2 ft^2 open bottom TLs, so high Qt. Fs was around 40 Hz and had output to 10+ kHz for good overlap with a 1st order XO. My memory is they're AlNiCo, but an easy way to tell is wave them around a CRT TV or monitor, small compass, etc.. If it doesn't affect it, its AlNiCo.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#7 |
Nice guitar speakers IMO, suit most probably jazz guitar, open baffled. They are AlNiCo magnets, couldn't be anything else with that shape. Other than retro radiogram / jukebox rebuilds, not suited to hifi. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#8 |
interesting, maybe i will build a little guitar amp?
#9 |
critical point. I guess most of the ALNICOS I've seen have that horseshoe looking thing around them, but it looks like I'm wrong. I don't have a lot of experience with old speakers so I was giving my best guess.
PASSIONN |
#10 |
Why don't ALNICO magnets effect CRTs?
PASSIONN |
| Tandberg TR2075 stripdown - identification help needed | jpcoetzee | Solid State | 9 | 14th December 2011 05:26 PM |
| Meridian DSP3200 full range driver identification | mrwireless | Full Range | 11 | 17th January 2011 08:39 PM |
| Driver Identification (Lowther?) | axissilverhand | Full Range | 8 | 15th November 2010 06:55 PM |
| Counterpoint SA-5000 P.S.U part identification needed | Tubologic | Tubes / Valves | 1 | 4th June 2009 07:45 PM |
| Identification this driver | Piapia | Multi-Way | 2 | 19th February 2004 08:10 AM |
| Page generated in 0.11258 seconds (76.77% PHP - 23.23% MySQL) with 10 queries |
