Old 30th July 2011, 07:52 PM   #1
goody75 is offline goody75  United States
Default Zigmahornet Question?
I have a question or 2 about modifying the Zigmahornet design.
1) Are there any benefits/drawbacks to using a pair of full range drivers for each speaker instead of a single one? It seems like it might help extend the range or smooth out the frequency response of the driver??? Also, would a pair of drivers want a larger cabinet???
2) Could any of the cabinet dimensions be increased, especially the width so, for example, a 5" driver could be used?
I know very little about speaker design so I appreciate any feedback you all can give. Thanks.
Old 30th July 2011, 09:28 PM   #2
TerryO is offline TerryO  United States
TerryO's Avatar
I've built a fair number of speakers and interestingly enough, a pair of Zigmas.
It's an old design and has some serious drawbacks, however if you built a Bi-Pole version (one facing forward and one on the back) it would solve some of those problems. A pair of drivers would need a cabinet volume of twice the single driver size. Be aware that the port would also need to be changed as well.
If I were to do this, I'd build a cabinet that was essentially two regular cabinets back to back with the a common panel taking the place of the back panels of each cabinet.
If you're looking at a 5 inch driver, then you need an entirely different design. Truthfully, a cabinet needs to be designed for a specific driver and any attempt to do otherwise will give results that can vary from pretty darn poor to really awful.
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 30th July 2011, 10:48 PM   #3
frugal-phile(tm)
planet10's Avatar
Best to take the basic concepts (the only solid ones are aesthetic) and start from scratch.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 31st July 2011, 02:03 AM   #4
TerryO's Avatar
dave
Goody,
I didn't want to rain on your parade, but Dave's absolutely right.
There are a lot of recent, really well engineered designs out there.
The designs on Dave's site are a prime example and would certainly be the first ones that I would consider. I've heard a fair number of them and they're quite good.
Best Regards,
TerryO
Old 31st July 2011, 07:33 AM   #5
The Zigmahornet was the first speaker I made. It had its qualities for example when playing acoustic music, but it was in the end quite limited as well.
Old 31st July 2011, 08:06 AM   #6
hm is offline hm  Europe
hm's Avatar
Default double horn
"Are there any benefits/drawbacks to using a pair of full range drivers for each speaker instead of a single one?"
yes there is, but you need two different horns,
look my double horns, the Kornett XL fit with 5",
bass down 35 Hz, no imp below 50 Hz ~4 Ohm,
best soundstage by seccond driver indirect.
http://www.hm-moreart.de
Old 1st August 2011, 03:27 AM   #7
gychang is offline gychang  United States
I still have my ziggies, when I built them several years back I liked them so much I bought 2 more drivers. The sound recording is not good but my ziggies are here: http://www.youtube.com/watch?v=uFkuxKshWnw
I like them for casual listening of jazz, vocals without a sub in my small room.
Good sound from Phoenix, AZ
Old 1st August 2011, 06:11 PM   #8
zman01 is offline zman01  Bangladesh
Goody75,
If the Zigmahornet aesthetics is a strong point to you, then you might as well check out the Lotus:
http://homepage.mac.com/tlinespeaker...ies-061109.pdf
Tall and pretty slim. Folks who've built them like 'em. But as always YMMV, depending on listening tastes, musical preferences, source components.
Zigmahornet FE103E larkinrulez Full Range 53 25th October 2009 01:50 PM
Zigmahornet Plan drwho Full Range 78 2nd February 2009 10:34 PM
Zigmahornet flippinjaz Full Range 15 16th January 2009 01:11 AM
Zigmahornet Modification Shae Multi-Way 2 7th October 2007 01:02 AM
Page generated in 0.11306 seconds (76.23% PHP - 23.77% MySQL) with 11 queries
