I just got a pair of Mark Audio A7.3 and was thinking of using them with a helper woofer. I will still use my subs for the deep stuff. I was thinking of a two module system with both being sealed. Use the A7 from somewhere around 180hz - 300hz* up and the woofer and subs below that. I guess I would want a 7" or 8" woofer. What do people think of this idea?* Any suggestions on woofers that would be <$200 /pr?
Kris |
#2 | |
Kris - I think you're on the right track - for the 2 or 3 octaves proposed, your probably don't need an industrial strength room shaker (that's what the "subs" are for) . Something like the CSS SDX7, Silver Flute W17RC38, Peerless 830946, Vifa (now labelled ScanSpeak I think) P17WJ should be on your short list. No doubt other folks will add other candidates.
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#3 |
Hey Kris, chrisb has some great suggestions. I would also mention the Vifa(again now ScanSpeak) P21W 8" driver. If you look around Chops has a thread in the fullrange section using the P21W to support the bottom end with a Fostex FE-103 variant. That may give you some ideas for design also.
Peace, Dave |
#4 |
Correction here, chops thread on the FE-103 used with the P21W is in the multiway section of the site. Sorry about that error. Still a good thread to read.
Peace, Dave |
#5 |
Chrisb,
Taking the helper woofer concept one step ahead, would sub-woofers be able to integrate directly with something like an A7? I understand I'll have to cross lower (100-120 Hz maybe), but what do you think on integration? 2 small subs using either of these: http://www.tb-speaker.com/detail/1208_03/w5-1138sm.htm http://www.tb-speaker.com/detail/1208_03/w8-1363sb.htm Of course the condition is that there should be no detriment to the Alp 7 sound overall -Zia Last edited by zman01; 30th July 2011 at 03:48 AM. |
#6 | |
Bob |
#7 |
Bob,
I now have my eye on the SDX7. My initial plan was to go for a driver around $50-$60, but looks like I will have to stretch a bit. And yes, dual subs.. |
#8 | ||
This is true, these Vifa P21WO drivers are wonderful sounding and can cleanly extend rather high, upwards of 2kHz. However, I'm only running them to around 700Hz, crossing over to the Fostex FE103E drivers. The really nice thing about the Vifa drivers is that in the right enclosure, you don't need a sub at all. In my 2.34cf ported enclosures which are tuned to 29Hz, I get solid, detailed, musical bass all the way down to 20Hz or so. They dig every bit as deep as my NHT 2.9's but actually sound better doing so than the NHT's! Just some food for thought...
Charles |
#9 |
#10 | |
Charles |
| suggestions for simple amp wanted | x9moto | Tubes / Valves | 16 | 2nd July 2011 11:47 PM |
| Suggestions / help wanted; low section in three-way ? | Empee | Multi-Way | 4 | 2nd January 2009 11:25 AM |
| Looking for a replacement for Maggies, suggestions wanted | EEatKSU | Full Range | 14 | 19th December 2007 11:42 PM |
| wanted: suggestions for a linaeum based design | zobsky | Multi-Way | 12 | 2nd August 2004 05:37 PM |
| Amp Suggestions Wanted! | Tall Shadow | Solid State | 20 | 9th December 2002 01:25 PM |
| Page generated in 0.11872 seconds (79.58% PHP - 20.42% MySQL) with 10 queries |
