help needed: Alpair 7 in a large room
Old 25th July 2011, 12:42 PM   #1
KrakBoem is offline KrakBoem  Netherlands
Unhappy help needed: Alpair 7 in a large room
Hi everyone,
I'm planning to build an Alpair 7 project (Twin Alpair 7 DBR or GR dMar-Ken7) with a subwoofer. I have a large room. That's why I was thinking of the Twin Alpair 7 (Higher SPL). No earthshaking levels requirered. No home cinema use.
The problem I face is room gain. With my current small 2 way BR monitor I made this measurement on listening position (10 feet). Speakers are close to the wall and one is in a corner.
I'm thinking of a Full range + Sub. So my plan is to have an equalized sub and full range main speakers without filtering/EQ. I assume that I have more control over the bass with a sub, because I have more options for room placement and EQ. The position of the main speakers is fixed (after years of negotiations with my wife). I have some more freedom in placing the sub (a marginal result, but it could turn out to be enough).
To have more control over the low frequencies, what is the best solution:
1. Should I go for sealed enclosures instead of BR?
2. Is it possible to design a full range with sealed enclosure without any filtering, and have it roll-off from 200 hz or lower?
Kind regards,
Kees
Old 25th July 2011, 09:45 PM   #2
chrisb is offline chrisb
how large exactly? area / volume if not standard ceiling height / slope etc.
with low frequency support at XO frequencies appropriate to the room, a pair of Alpair 7s per side should be able to satisfy most (sane) musical listening requirements
of course it's possible to size a sealed enclosure for a full range driver to provide acoustical roll-off at a chosen frequency, but it wouldn't necessarily yield the best results at the low extent the driver's pass-band - if at all possible, I'd suggest you consider passive line level XO and active bi-amping
Old 25th July 2011, 10:18 PM   #3
tuxedocivic is offline tuxedocivic  Canada
tuxedocivic's Avatar
That is quite the room mode. I'd go sealed with both the sub and Alp7s. Eq that huge mode out of the 40 to 80hz range from the sub.
Old 26th July 2011, 09:29 AM   #4
My room is 60 square meter (aprox 640 square feet) and 2.6 m high (8.5 feet).
So it will be sealed enclosures and an active subwoofer with EQ. Maybe I'll use a Minidsp for this.
Thanks for your help.
Old 26th July 2011, 09:44 AM   #5
No idea where that frowning smiley came from. How do I get rid of that?
Old 26th July 2011, 09:51 AM   #6
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
What frowning smiley?
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 26th July 2011, 11:27 AM   #7
In the title "Help needed"
help needed: Alpair 7 in a large roomHide this!Advertise here!
Alpair 6p vs alpair 6m vs alpair 7 timreeves Full Range 11 8th January 2013 03:37 PM
Which small speaker design for large room? wixy Full Range 24 1st January 2011 12:15 AM
Question on room mode excitation with large area planars LineArray Planars & Exotics 2 21st November 2010 01:23 PM
Need speaker recommendations for a large room.... blake_mooney Multi-Way 14 24th April 2007 05:22 PM
Cheap design for large room chrish Multi-Way 18 16th October 2005 09:41 AM
Copyright ©1999-2017 diyAudio
