Old 24th July 2011, 08:43 PM   #1
Default recomendations please
started an open baffle project and am really happy with the initial results, im using 15" eminence Beta woofer in a folded baffle and a skytronic 12" full range in full open baffle
have a x-over crossing at 250hz
Now the skytronics are el cheapo drivers and have done ok but i want a better driver now, have heard the visitron B200 is good, any others you would recommend 8" to 12" please 8 Ohm
My x-over was designed for the drivers being 8 Ohm if i use a 6 ohm like the visitron will i need to change the x-over?
Ron
PS would need something i can buy in europe, post is too costly from US
Old 25th July 2011, 09:58 PM   #2
Surely someone has an opinion?
Come on guys where are all the speaker experts?
Old 25th July 2011, 10:10 PM   #3
tuxedocivic's Avatar
The XO would likely need changing even if the impedance was the same. But the short answer is, yes, the lower impedance means the components will be more "effective" thus changing the XO point. It may work just fine, but it would be a fluke.
Old 26th July 2011, 01:19 AM   #4
Thanks,
I did a very simple 1st order butterworth x-over using this calculator ( crossing at 250Hz)
2-Way Crossover Designer / Calculator
i used simple iron core 1mm inductors and cheap caps to the specified values. the result is bloody amazing and im well pleased my standard speakers are Living voice avatar II so not shabby and im using hyperion HT88 SE monos to drive them.
Bass is suprisingly deep, not earth shaking but musical and detailed. The mid and treble is good also if a little shouty at hi volume levels but very entertaining.
I think if i god a better pair of 8 Ohm full range i would hear the benifits.
Wouls good components like mundorf in the x-overs make a big difference to sound quality?
Recomendations on build tvrgeek Solid State 2 24th January 2010 02:24 PM
Amp recomendations kzeprf22 Solid State 0 16th December 2008 09:37 AM
Amp recomendations skooter Car Audio 10 3rd November 2007 05:13 AM
X-over software recomendations pjpoes Multi-Way 21 9th April 2007 07:50 PM
Music Recomendations Milzie Multi-Way 4 20th January 2003 02:49 AM
Page generated in 0.09348 seconds (67.53% PHP - 32.47% MySQL) with 10 queries
