Old 22nd July 2011, 01:49 AM   #1
zman01 is offline zman01  Bangladesh
Default Wessex MLTL with CSS EL70
Dear all,
My weekend project is final - Wessex MLTL - this pretty much jumped my build queue in the past week or so. Lotus^2 will have to wait for now...
http://homepage.mac.com/tlinespeaker...v92-151209.pdf
I am opting for the narrow baffle variation mainly due to room width factor. Besides the tall and slim profile should be nice to the eye . I am planning to do a 45 degree chamfer on the edges of the front baffle to further accentuate the slimness and help the speakers "disappear" better.
I will build this with a removable back so that damping material adjustment is possible later.
I see the plans have are with round ports only... I wonder if slot ports are also possible?
The other thing is that I have searched high and low for a Wessex build thread or review - found none. Is this the first time somebody will do an actual build?
Will keep posting as the build progresses.
-Zia
Old 22nd July 2011, 02:36 AM   #2
jimbro is offline jimbro  United States
You know I'll be watching. What the heck are you doing with all these speakers you're building?
Old 22nd July 2011, 02:47 AM   #3
Good question. Mostly irritating my wife, I guess.... .
After I'm done building, the keepers stay with me. Rest of the cabs I give away or throw away.
Old 22nd July 2011, 03:26 AM   #4
frugal-phile(tm)
planet10's Avatar
Yes. Keep the area & length
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 22nd July 2011, 03:41 AM   #5
dave
Thanks Dave - will put GMs formula to use here. BTW, with slot port, can I expect just a bit more finesse on the low end without loosing grunt?
-Zia
Old 22nd July 2011, 12:19 PM   #6
Default Port spacer for Wessex slot port
Dave,
I see a "Port spacer" for the optional slot port of the EL166MLTL - for 165mm total available port width, the ports are 54mm each, with a 57mm port spacer between them.
For internal baffle part width of 146mm for Wessex, I have taken a port spacer of 50mm, and the 2 slot ports will be 48mm each. The port spacer will run to the back of the port shelf.
Should work? Or spacer should be narrower/wider?
-Zia
My brief CSS EL70 review 60ndown Full Range 5 28th May 2011 12:31 AM
Offset Bipolar MLTL with CSS EL70 Drivers--Part 1 Jim Griffin Full Range 44 28th July 2010 04:53 PM
CSS FR125S, Alpair 7 & CSS EL70? Monte Verdi Markaudio 6 29th June 2010 08:51 PM
Introducing The new CSS EL70 CSS/XBL CSS 41 19th April 2010 09:23 PM
Page generated in 0.09509 seconds (77.09% PHP - 22.91% MySQL) with 11 queries
