So my GRS FR-8 drivers and waveguides arrived yesterday. After removing the dustcaps and a quick trip the the hardware store, I've come up with what you see below. Yeah...not pretty. I'm going to burn them in a bit and try them on an OB just for the experience, but without testing equipment I'm pretty much just driving in the dark with no lights on. The inspiration for this frankenstein of a driver was this.
Then again, what do I know?
#2 |
Isn't all that added mass going to have a wee bit of effect on the TS params?
mike - www.keepingsundayspecial.org |
#3 |
No added mass, it's acting as a phase plug. The reduction of Mms by removing the dustcap will undoubtedly have an effect though. How much I can't say; like I said, I'm in the dark here!
#4 |
Hi Chazdrumzalot,
I hope you are in a position to do some acoustic measurements on this setup, which would interest me a lot. It could lead to a lot of diffraction ripple on axis, but then again, it might not and it might be great, vac
If my 15 V DC were the radius of the Earth, Mount Everest would be 1 meter tall. |
#5 |
Do you have a driver at the throat of the waveguide? Or is the waveguide just a phase plug?
Me and my friend were talking about such an experiment with a front loaded horn for a big woofer and a smaller horn for a compression driver mounted coaxially. Hard to pull off though. |
#6 |
Why mess with some disaster like this?
![]() when it's easy to get this,open baffle, w/o all the fuss? ![]() grn 0 red 15 purple 30 blue 45 orng 60
"...His brain is squirming like a toad..." Jim Morrison |
#7 |
Why would you build an OB if you can fold that baffle into an enclosure and get something like this:
zelfb2.jpg Measured at 0-45-90 degrees Seems flatter on a 5 dB scale than the OB at a 15 dB scale.
#8 |
I had similar project, except a tweeter was attached to a horn.
Imageshack - img0462pz4.jpg Imageshack - cimg1240qs0.jpg Imageshack - h511omnisb5.gif |
#9 |
Well... those traces were in room 15 feet distance... here's near field set up "flat"
sounds WAY TOO BRITE!! ![]() ![]() ![]() and 15 feet away, setup "FLAT" ![]() funny how smoothing and setup can influence a plot, eh? Not to mention test conditions??
#10 | |
Mistertwister, your project looks interesting. The next logical step with this is to install a helper tweeter inside the waveguide. Do you document your project anywhere?
| xt25 in 12in waveguide experiment | MisterTwister | Multi-Way | 65 | 23rd July 2010 06:08 PM |
| Small fullrange for waveguide loading | Defo | Full Range | 6 | 25th May 2010 08:14 AM |
| EXPERIMENT - Small driver in a big pipe/horn - does it need a sub? | just a guy | Full Range | 31 | 18th September 2008 09:52 PM |
| Another PR170M0/Waveguide experiment | AJ | Multi-Way | 50 | 10th February 2008 02:40 AM |
| Experiment in single driver OB | mashaffer | Full Range | 9 | 13th May 2006 04:17 PM |
| Page generated in 0.11375 seconds (87.43% PHP - 12.57% MySQL) with 11 queries |
