I am new to open baffle speakers and I have being delving heavily into the theory of late. To bring myself up to speed I made a spreadsheet just to model the comb filtering on axis as a result of the delayed rear wave arriving with the front wave.
Initially I left out the effect of sound propagation from a point source (a.k.a the inverse square law) because I was not sure if it varied with frequency. When plotted, I obtained the classic open baffle curve (first picture below). This was based on a listening distance of 2m in free space and with a circular baffle of 1m diameter. Now, the inverse square law applies equally to all frequencies. High frequency loss is attributed to the effect of air absorption which is quoted typically only 0.5dB/100m and so can be safely ignored here. [http://www.sfu.ca/sonic-studio/handb...pagation.html] When I add in the effect of the inverse square law, i.e. the rear wave being weaker by a factor of (2/2.5)^2 = 0.64 because it has travelled 2.5m instead of 2m, the graph changes drastically (second picture - same parameters, same scale). What have I got wrong? Tim. |
#2 | |
Below is what you should expect. (It's a real pity that you can't use EDGE )Rudolf
www.dipolplus.de |
#3 |
Mmm. I believe in the laws of physics, at least as an excellent approximation. I think you may let me get away with saying that another way of putting what you wrote it is: at baffle sizes much less than a wavelength the source does not behave like a point source.
It is fascinating that a relatively small attenuation of the rear wave would create such a drastically different summed response. The second of the two graphs was brought about by factoring in less than 4dB of rear wave attenuation! I wonder if more effort should be put in trying to attenuate the rear wave? It is. I can't find any Mac equivalent but there are signs of activity in the speaker department of the iOS app store. Tim. Last edited by timmillea; 20th July 2011 at 04:50 PM. |
#4 | ||
www.dipolplus.de |
| Square Law Class A Amps | Onvinyl | Solid State | 35 | 23rd May 2012 05:32 PM |
| Tube Square-Law, what and how to set up? | ervinl | Tubes / Valves | 9 | 20th August 2010 11:49 PM |
| Modelling a semi-open-baffle in WinISD for use with a sealed-box woofer? | Spasticteapot | Multi-Way | 2 | 27th November 2006 09:49 PM |
| For modelling open baffle: MathCad v Excel | rick57 | Full Range | 20 | 6th October 2006 08:32 AM |
| what effect does baffle have on open-baffle system? | kappa546 | Multi-Way | 6 | 24th January 2006 10:21 PM |
| Page generated in 0.07744 seconds (83.89% PHP - 16.11% MySQL) with 11 queries |
