Old 20th July 2011, 12:47 AM   #1
Abob89 is offline Abob89  United States
Default New toys but not sure what to do with them
Hey Fellas,
I recently traded some labour with a friend for his Hybrid Audio Technologies Legatia 4" drivers.
Now, these are primarily Automotive drivers. But they have a massive bandwidth. They claim a solid 160 to 16k. I know a few people in the car audio industry who will even forego the use of a tweeter when using these drivers due to their high end reproduction.
I don't really have any use for these little lovelies in my car at the moment since I already have that built. Instead I'd love to find a use for them in my house. I will eventually be using a 25w per channel SIPP tube amp I'm building with a friend on these. We're assembling the powersupply this week. Until that is finished however I will be running them on a small 3-4 watt single ended tube amp.
I listen to a lot of electronic music, including Glitch and Drum & Bass. But I also like my Janis Joplin too, not to describe my musical tastes as an ecclectic mess though . Rest assured I'm not expecting BASS for my techno, but if I can salvage any midbass that would be nice.
I'm looking for a jumping off point, something to work with because I don't really have a lot of knowledge on interpreting T/S parameters.
http://www.hybrid-audio.com/Legatia%20L4.pdf
Overall Diameter φ118 mm (4.65-inch)
Mounting Depth 54 mm
Bolt Circle Diameter φ109.5 mm
Mounting Hole φ94.5 mm
Recommended Minimum Crossover Frequency 160 Hz at 24 dB/octave highpass
Pnom Rated Power Input (No Crossover) 30 watts (AES Standard)
Pmax Rated Power Input (No Crossover) 60 watts (AES Standard)
Pmax (With Recommended Minimum Crossover) 150 watts
Frequency Range 90 Hz - 17,000 Hz, +/- 3 dB
Sensitivity 89 dB at 1 watt/1meter
Mms 4.22 g
Cms 706.4 um/N
BL 3.74 T*m
Voice Coil Diameter 25.5 mm (1-inch)
Impedance 4 Ω
DC Resistance 3.4 Ω
Fs 90 Hz (free air)
Qms 2.61
Qes 0.61
Qts 0.50
Xmax 3 mm (one way)
Vas 2.54 L
Sd 5000 mm2
Any help would be greatly appreciated.
Abob
Old 20th July 2011, 01:11 AM   #2
sofaspud's Avatar
I could well be wrong, but these are the sort of drivers I thought would work in a Zigmahornet cabinet.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 20th July 2011, 01:26 AM   #3
S'funny my tube friend said they look like that too.
Old 20th July 2011, 03:48 AM   #4
frugal-phile(tm)
planet10's Avatar
I'm not very enthusiastic about the ZigmaHorn.
I don't see anything in the specs that would preclude using it as a FR.
To help with the lowish xmax, the Frugel-Horn Mk3 might be considered.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th July 2011, 04:17 AM   #5
Scott Buwalda, the company's creator classifies them as a midrange. However, the frequency response is what really draws me to the driver.
Thank you for the recommendation Dave.
Old 20th July 2011, 04:43 AM   #6
Abob89......if you're not too far from Portland I have a set of Zigmahornets we could throw them in for you to hear before you built a pair.
Old 20th July 2011, 04:57 AM   #7
That would be pretty cool! I'm Vancouver, just across the border
Old 20th July 2011, 05:07 AM   #8
I'm not far from the river.....at I-84 and I-205. Let me know when you want to cruise down. I can have an amp and source ready or you can bring yours if you'd like.
Old 20th July 2011, 04:20 PM   #9
I thought 3mm one way x-max for a 4" driver was ok?
You'll be able to get down to ~80Hz if run full-range, perhaps a filter at 80Hz to reduce useless excursion at LF.
Old 20th July 2011, 04:28 PM   #10
frugal-phile(tm)
planet10's Avatar
I mistakenly read 0.3mm. Yes 3mm (ie 6mm p-p) is lots.
dave
New toys TA2020 zlab Class D 18 12th January 2010 02:22 AM
got some more class d toys Tekko Class D 5 28th November 2007 01:17 PM
My new toys pinkmouse Multi-Way 15 25th May 2003 09:31 PM
More new toys pinkmouse Parts 0 10th May 2003 08:20 PM
cheap toys karma Everything Else 8 30th April 2003 08:39 AM
Page generated in 0.12327 seconds (78.27% PHP - 21.73% MySQL) with 10 queries
