Now i have some 'Time' and some 'Money', Im looking to build a diy hifi system (again) after a 16yr lay-off. Mother got the last build as i was fed-up of her poxy one box system,it still sounds good all these years later, though it could prolly do with a bit of a service ect.
Just recently ive been listening to alot of simply arranged music and thought of Mr.Pass's electronics and of horn 'speekers.................. Zillion credit Question is, will/would the new fe166en work in the Dalek horn? I did see the post by Oktyabr asking the same Q but regarding Ron Clarke's Austin A166, so i went and looked for info on the A166 and see from the 'final' drawing that theres some le-way in the chamber to make it larger and pack it down to lower the internal volume. It says in the orig Dalek artical that the horn throat was too big and was altered by useing sand filled cones, the drive chamber could also be made detachable for tuneing. just a thought like. Any thoughts? |
#2 |
frugal-phile(tm)
FE166En should work fine. You might need to fine tune the air-cavity
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
Thanks Dave,
Any recomendation as to which way i should increase the chamber size, ie larger dia, more length or a bit of both? |
#4 |
frugal-phile(tm)
No. You'll have to play it by ear.
dave
#5 |
Ok, thanks again Dave........
will document my build when it gets under way. |
| Some FR measurements of the new FE166En | Bob Brines | Full Range | 19 | 3rd May 2012 08:42 AM |
| Need help (Fe166En) | nightuser | Full Range | 11 | 1st May 2011 05:31 PM |
| fe166en Question | kennyhorn | Full Range | 2 | 18th October 2010 08:34 PM |
| FE166En different from FE166E? | louischia | Full Range | 3 | 3rd October 2010 02:46 PM |
| dalek speaker build question | babgrip | Full Range | 5 | 31st August 2009 02:26 AM |
| Page generated in 0.08124 seconds (74.00% PHP - 26.00% MySQL) with 10 queries |
