Old 15th July 2011, 12:41 AM   #1
KnJ is offline KnJ  United Kingdom
Default Connect a passive speaker driver
Hello.
I bought a qtx sound passive speaker driver(902.545).
But, I don't know how to connect.
I've done to directly connect an amplifier to the speaker driver with a cable. But, It didn't work at all.
I checked my amplifier, but it's ok..
Could you let me know how to connect?
Do I need something more to connect?
Thanks in advance
Old 15th July 2011, 02:32 AM   #2
Pano is offline Pano  United States
Pano's Avatar
That's a 10" woofer, right? It should work if connected to an amp. Does the amp work on other speakers?
How are you connecting it to the amplifier?
Take the Speaker Voltage Test!
Old 15th July 2011, 02:47 AM   #3
I don't think it's an woofer. It's a full range passive speaker.
DJ Speakers, Disco Lights, PA Systems, Lighting & Effects, DJ Equipment, DJ Kits - 10 Inch 200W 8 Ohms Full Range Passive Speaker Driver
I connected my laptop to my amplifier.(Connect the cable to L channel of Speaker A) - my amplifier has L(+,-) R(+,-) of Speaker A,B(total 8 connectors)
And, the amp works well when I take a headphone instead of a speaker.
Connecting to speaker driver is the same way to connect to a passive speaker(with a cabinet)?
Old 15th July 2011, 02:54 AM   #4
Pano's Avatar
Yes, connecting the driver is just the same as connecting a speaker in a cabinet, except the terminals are a little different.
You can check the driver with a 9V battery (the square type) to see if it moves. Just touch the battery to the terminals, it should jump a good bit. A 1.5V AA or AAA will work to, if you can get both ends connected.
Old 15th July 2011, 03:02 AM   #5
Could you let me know exactly how to check my driver?
Just touch the battery(I have AA batteries) to each terminal? without any connection to the amp?
Thanks for your answer~
Old 15th July 2011, 03:05 AM   #6
Pano's Avatar
Yes, just the batteries and the driver. Don't connect the amp. You can put the batteries on the wires in place of the amp - if you see what I mean.
Old 15th July 2011, 03:06 AM   #7
just another
wintermute's Avatar
yes that should do it. 9V pano I've only ever been game to use 1.5V aa's
then you can determine which speaker terminal is the positive and which the negative by which direction the cone moves when the terminals are touched to the battery. When the cone moves out ways the lead connected to +ve on the battery is the positive of the speaker.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 15th July 2011, 03:08 AM   #8
Pano's Avatar
The driver is rated at 100 watts. 9V won't hurt it. I don't suggest leaving it there overnight.
Old 15th July 2011, 03:16 AM   #9
I see~
I'll try that.
If it doesn't work with batteries, probably a stupid driver?
Anyway, thank you so much~!
I'll go to test right now.
Old 15th July 2011, 03:19 AM   #10
Speakerholic
Cal Weldon's Avatar
Ya, a 9V will give it a nice stretch. Do you happen to have a multimeter? If so you can check the DCR and/or run a continuity test.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
how to connect t-amp to a single speaker fishline Class D 7 24th February 2009 01:00 PM
Speaker connect: Speakon or banana Serge66 Tubes / Valves 12 14th January 2008 08:29 PM
How to connect multiple drivers to Passive crossover Toast_Master Multi-Way 13 13th May 2006 09:02 AM
Best way to connect wire to your driver terminals andy2 Multi-Way 1 22nd August 2005 06:48 AM
Connect cable to driver, don’t sizzle voice coil? rick57 Multi-Way 3 18th February 2005 08:52 AM
Page generated in 0.12214 seconds (76.19% PHP - 23.81% MySQL) with 10 queries
