Old 13th July 2011, 09:25 AM   #1
fiacca is offline fiacca  Italy
Default Dipole questions
Good day all, I have been playing with OB for a few months, I built a copy of Martin's one and I am quite satisfied of the result.
While searching the web on the matter, I found out an interesting project called "Sealed Dipole"
DIY Sealed Bipole Speaker Project with Fostex FE127E Driver
I am wondering about the result of putting 2 couples of identical loudspeaker back to back.
Will they act as bipoles or what?
One of the projects I am plannning is the VTL with Jordan fullrange, what if I built 4 of them and put them back to back?
Thanks Piero
Old 13th July 2011, 11:00 AM   #2
Careful with your words--bipole and dipole. If you have two drivers mounted back to back and connect them in phase, you will have a bipole speaker. Connect them out of phase and you will have a dipole speaker. Bipoles have a broad radiation pattern and sound essentially omnidirectional in a room. Now dipoles have a figure eight radiation with cancelation in the plane of the speakers. Expect limited limited bass from a dipole speaker unless the drivers are mounted in large baffles so that the front and back radiations don't cancel.
line array, mulitple drivers, dipole .. questions that need answers! JinMTVT Multi-Way 4 6th April 2010 09:53 AM
power response of dipole questions thadman Multi-Way 1 2nd July 2007 12:19 AM
Dipole questions using Seas Excel tf1216 Multi-Way 3 2nd March 2006 07:45 PM
Folded Baffle Dipole Sub questions johninCR Subwoofers 8 4th May 2004 07:32 AM
Dipole sub parameters questions A3rd.Zero Multi-Way 6 29th April 2004 03:10 PM
Page generated in 0.06718 seconds (68.43% PHP - 31.57% MySQL) with 10 queries
