Hi all, I would like to build inverted BiB using ZiIllaaudio calculator. Looking at this argument in other threads it seems overall dimensions of cabinet are the same both for ordinary and inverted BiB. But Z-driver value cannot be the same of course. I've found a value of 0.416 * line length Can this work fine? Or are there other calculators for iBiBs?
Thanks a lot Ziocalepino |
#2 |
According to MJK it is.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#3 |
MJK?
#4 |
#5 |
Thanks for link. Another important, for me, question is: is there a real advantage to build inverted BiB instead of normal? A part no dust into cabinet...
Thks |
#6 |
If your driver doesn't warrent a long line, your BIB is going to be too short to use the ceiling effectively for loading. Then it might be better to invert. Also for some it might be an opportunity to get the right driverhight without resorting to tricks and compromises.
| iBIB for FE208Ez | pengesluk | Full Range | 3 | 16th May 2011 06:42 PM |
| BiB Vs. iBiB | ziocalepino | Full Range | 32 | 2nd February 2011 01:43 PM |
| Multiple driver MMT calculation question | JohnIsBaffled | Multi-Way | 3 | 4th August 2008 01:31 PM |
| Driver Power Calculation | GOWA | Multi-Way | 2 | 12th November 2007 09:40 AM |
| Calculation of power required by driver | PaulHilgeman | Solid State | 0 | 6th May 2003 02:05 PM |
| Page generated in 0.07777 seconds (82.71% PHP - 17.29% MySQL) with 10 queries |
