Cabinet dimension advice
Old 19th July 2011, 05:00 PM   #11
GM is offline GM  United States
GM's Avatar
Originally Posted by awol66 View Post
Thanks for the reply GM
ok , so i wasnt planning on actually building the full horn , but i thought that was my starting point , and then
presumably i would either scale the whole thing down to a useable size (i assume shrinking it would raise the BW (bandwidth?)
and reduce the efficiency ) or i use the upper section of the horn to construct a metronome design
You’re welcome!
Yes, shrinking it will shift its gain bandwidth [BW] higher, but trying to scale it isn’t the best way to do it. Instead, you cut a section out of it.
A Metronome appears to be a mass loaded [ported] conical pipe, so for a driver with a lower Fs, Vas, Qts than the FR6.5C it would theoretically require a much longer, slower expanding [narrower] horn tuned lower, so may need to be folded to get the driver ‘up’ to an acceptable listening height.
To get a quick approximation to build or just use as a starting point in a modeling program, I used the BIB pipe horn calculator [comes to a pointed closed end Vs the Metronome’s truncated one] tuned to 36 Hz [i.e. inputted 72 Hz to get an Fs tuning]:
L = ~93.5” [path-length]
Sm = ~200”^2 mouth [base] area
h = ~46.75” [folded]
w = ~11.89”
d = ~16.81”
a-b-c = ~8.41”
zdriver = ~6.92” [This would put the driver center ~40” off the floor]
net Vb = ~5.41 ft^3
All dims are inside [i.d.] and approximate. Yours would be inverted from the attached layout with a bottom plate to close off the terminus.
Based on the net Vb, the vent would be at least a 3.5” diameter hole 0.75” long [baffle thickness], but the pipe’s loading will dictate a larger hole and may need to ideally be a bit longer to ensure a low vent mach if the driver can handle much power down low, though I don’t recommend longer than ~3”. This can be calculated/modeled ‘close enough’ using MJK’s MathCad, HornResp, AkAbak or similar software or do as I did and find it empirically. The vent can be on one of the sides near/at the bottom or even on the bottom if spaced up off the floor like a Metronome, then model an alternate driver location if it’s too high off the floor.
Some baffle step compensation may be required to make it nominally tonally flat in-room.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 19th July 2011, 07:02 PM   #12
awol66 is offline awol66  England
awol66's Avatar
thank you very much GM , i appreciate you going to the trouble of working out those numbers for me .
the next step for me is to go away and think about how near i get to those dimensions with the materials
i have to hand , got some blockboard offcuts about 48" x 11 1/2 " and some old shop shelving , also
blockboard , that will do the sides . a cunning plan is begining to form
thanks again GM , i will post up picks as i go along now ive found out wot the upload limit is .
wot are all these buttons for?
Old 29th July 2011, 03:31 AM   #13
GM's Avatar
You're welcome! Hope you can come up with an inexpensive, yet great performing system.
GM
Cabinet dimension adviceHide this!Advertise here!
need advice regarding painting the cabinet eitanwaks Multi-Way 2 23rd November 2009 09:11 PM
New Cabinet Opinions & Advice Sought Thomo Full Range 8 30th December 2008 11:03 PM
1x10" Guitar cabinet advice hpl Instruments and Amps 3 22nd August 2008 10:52 AM
Need advice on cabinet finishing (lacquer) alphaGeek Multi-Way 23 25th March 2003 05:24 PM
