Old 10th July 2011, 07:03 PM   #1
Bigun is offline Bigun  Canada
Bigun's Avatar
Default mMar-Kel70 vs Mar-Kel70
I now have a pair of new EL-70's on the shelf
I also have some Onken style boxes (a.k.a. derived from planet10 Fonken) which are very close to the mMar-Kel70 enclosures - mine are 6l with ports that are the same length but larger in area (I can reduce the area accordingly). Seems an easy path forward.
But I have enough of these boxes that I can combine them (with some surgery) to make a pair of larger boxes which have a volume just a couple of litres more than the bigger Mar-kel70.
Question: how would you contrast these two designs in terms of sound ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 10th July 2011, 07:38 PM   #2
frugal-phile(tm)
planet10's Avatar
Base volume of mMar-Kel is 4.7 litre, the Mar-Kel70 is 13 litre.
mMar-Kel sounds good but has a character in the mid-bass, upper bass that intimates, "i'm being held back by the small volume".
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th July 2011, 08:48 PM   #3
Bigun's Avatar
Dave,
Thanks for the rapid response !
Let me ask - do you think this character is related to the restricted volume ? - I'll have 6 litres on tap which gives me more room in this case if re-use the existing boxes.
OR do you think this character is related to the room around the driver ? - I'll have 15.1cm of width between side walls where the driver sits, the mMar-kel70 has 14.3cm. I combine some boxes to get a larger volume this wouldn't change ?
Old 10th July 2011, 09:09 PM   #4
frugal-phile(tm)
planet10's Avatar
Sounds more like a volume issue. You get the feeling that the driver is being held back (and listening to the fullSize miniOnken, it is)
The millisize got to the width they are because of early reflections on the inside (took us 3 prototypes to get the shape right.
dave
Old 11th July 2011, 11:58 PM   #5
Bigun's Avatar
Good to know.
How important is recessing the driver into the front baffle - as there's already a hole cut out and the FE127 was not recessed it will be difficult to route a recess as the centre of the circle is in mid-air ?
Old 12th July 2011, 12:08 AM   #6
frugal-phile(tm)
planet10's Avatar
With the fat bezel of the EL70, i'd say it is very important to get it flush, whether that be a rebate or building up around the driver.
dave
Old 12th July 2011, 01:42 AM   #7
Bigun's Avatar
I suspected as much - I can see now from the drawings for the mMar-kel70. Well that's going to be a bit of extra work to figure out. In the meantime I want to know whether these drivers make a sound
I did enough surgery to the driver magnet brace to allow me to install the drivers and connect the boxes up to my tube amp. The tuning is way off, I still need to reduce the area of the ports. And the tube amp is wired up for an 8Ohm load not a 4Ohm load. But it allows me to put some noise into the drivers.
I can already tell that a) there is waaay more bass than the FE127. b) the shrill of the 7kHz peak from the 127E is not present, c) the box tuning is off and d) the drivers need time to break-in.
The mounting screw holes don't line up with the old drivers. Fortunately the old holes don't go all the way through. If I like them the boxes will escape the bonfire and I'll probably take some time to refinish them - the veneer has not survived the test of time and needs to be removed. I'm tempted to spray paint the boxes.
Too early to say more.
Old 12th July 2011, 09:55 PM   #8
Send a message via Skype™ to Rullknufs
dave
Do you think i should do that with my Mar-Kel70? Is it worth the job?
Old 12th July 2011, 10:03 PM   #9
frugal-phile(tm)
planet10's Avatar
Yes, when you rebuild them proper
The 12mm chipboard probably wouldn't survive
dave
Old 12th July 2011, 10:08 PM   #10
dave
I'm not sure if i will rebuild them proper. Maybe if my dad has lots of spare time in his semester i may ask him if we should have a go at it.
I was more thinking about finding something that is 6mm thick and mount it on the outside of the baffle. And then sand it into a custom shape or something. Might end up quite cool if i do it like egg-shaped and a hole in it for the driver. What do you think? Wouldn't that be good for baffle diffraction stuff?
Mar-Kel70 in Sweden Rullknufs Full Range 1047 18th March 2012 01:42 AM
Mar-Ken12 krips Planet 10 hifi 33 17th September 2011 03:33 PM
Phonic - MAR 4 mudanov Instruments and Amps 1 4th August 2011 12:44 AM
Phonic Mar 6 Amp kinser Solid State 8 11th October 2007 11:05 AM
Page generated in 0.12354 seconds (78.33% PHP - 21.67% MySQL) with 11 queries
