I've almost finished building a pair of Saburos. Lord, have they taken a long time to get this far! I am about to glue the final side on. I'm just wondering, from comments seen elsewhere, whether I ought to put some sort of high frequency damping material inside the thing, perhaps in the compression chamber, before I glue it all up. It would be much easier to do this now with the side off rather than try and do it through the driver hole afterwards. Any opinions on what's best?
#2 |
Air cavity / low-pass chamber. The room is the compression chamber in back-horns (well, 99.999% of them at any rate.
Damping tends to be rather dependent upon the rest of your system (primarily the amplifier & room), to say nothing of personal taste. Generally, lining the chamber with 1/2in felt or similar, or adding a small amount of stuffing is a reasonable starting point. |
#3 |
Thanks Scott,
I have some ordinary tailors' felt, but nothing like half inch thick. Any ideas for suppliers? Wilmslow Audio sell some damping materials including BAF wadding (whatever that is), lambswool and various foam constructions, but not felt. Am I right in thinking that the felt will just attenuate the high end? Or is its purpose primarily to stop reverberation? |
| Ideas on Internal Wiring for Saburo | CastleJohn | Full Range | 65 | 6th June 2011 03:39 PM |
| Saburo build question.... | PDRCanada | Full Range | 4 | 16th August 2010 08:11 AM |
| Internal Damping | morfius | Multi-Way | 25 | 25th February 2008 07:58 AM |
| Internal damping for BAMTM | Obiwan_cr | Multi-Way | 1 | 19th January 2008 03:38 AM |
| internal cabinet damping gloop | jives11 | Multi-Way | 6 | 5th July 2006 09:29 PM |
| Page generated in 0.09058 seconds (71.86% PHP - 28.14% MySQL) with 10 queries |
