Old 8th July 2011, 05:27 PM   #1
Godzilla's Avatar
Default $5 woofers at PE might work on OB...
How low might this cheap 8" driver go on an OB or H-frame?
8" General Purpose 8 Ohm Ribbed Paper Cone Woofer
I'm wondering how these might perform in H-frames (one or even two) powered by a sub amp as a slim subwoofer?
TIA
Old 8th July 2011, 05:30 PM   #2
chris661's Avatar
From memory, the mass-corner is Fs/Qts, which yields good results in this case.
I think I'd take 2 per side on a H-frame. At that price, you might as well buy a couple extra in case you blow some up
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 8th July 2011, 06:00 PM   #3
Pano is offline Pano  United States
Pano's Avatar
4 per side maybe. That's $16 per side. You might still have trouble getting down below the Fs of 45Hz.
Old 8th July 2011, 06:07 PM   #4
I recently tried an OB experiment with some very cheap "white van" type speakers. My buddy and I cut the speakers in half at an angle and then used iTunes to provide some semblance of a balanced response. What I can tell you is that while those cheap woofers did produce bass, it was pretty lousy bass. I got no impression of the clean, articulate OB bass people talk about. This leads me to suspect that there is a major difference between a "cheap" woofer like the alpha15 and a CHEAP woofer like what's in the white van speakers. That leads me to ask: what are the chances that this cheap woofer will really sound all that good? Isn't this the kind of woofer that shows up in white van speakers in the first place?
Maybe using 4+ per side will reduce distortion and improve SQ...
Then again, what do I know?
Old 8th July 2011, 06:10 PM   #5
Pano's Avatar
4 per side would give you a cone area of about 160 sq in, (I think) compared to the Alpha 15 at about 137 sq in. So each driver would not have to work too hard.
For the price of the Alpha 15 you could have 16 of these.
Take the Speaker Voltage Test!
Old 8th July 2011, 07:05 PM   #6
onform is offline onform  England
onform's Avatar
They look like you could have some fun experimenting with them!
Is there anywhere in the UK/Europe that does these sorts of deals??
Old 8th July 2011, 07:59 PM   #7
So what's the plan, guys? How about 8 per side, wired for a 4ohm load and 99db sensitivity; then put in an H-frame for a lower Fs and resulting lower Fo, and an overall sensitivity of 89db after dipole loss? I have to admit, it does sound appealing!
Question: can you place them side by side on an open baffle as opposed to stacking? So maybe it would look like:
OOOO
OOOO
or put a fullranger in the middle like...
O O
O O
o
O O
O O
Old 8th July 2011, 08:31 PM   #8
Tom V is offline Tom V  United States
Or six? Arranged in a circle with the full-ranger in the middle?
Old 8th July 2011, 09:31 PM   #9
Pano's Avatar
That might be fun.
But don't be shy, do 16 per side. 12, at least.
Old 8th July 2011, 09:34 PM   #10
That might be fun.
And what will SWMBO have to say to that idea?
Budget 12" OB candidate at PE for $29US mpmarino Multi-Way 0 1st May 2009 08:51 PM
OB 3 Woofers? NurEinTier Multi-Way 22 3rd July 2008 04:49 PM
OB efficiency with 2 or 4 woofers tinitus Multi-Way 29 19th June 2008 12:09 PM
Anyone tested 'Etone' woofers for OB? grantnsw Multi-Way 33 3rd March 2008 09:29 AM
Woofers for OB array G.L. Tirebiter Multi-Way 0 9th March 2005 04:49 PM
Page generated in 0.10868 seconds (74.36% PHP - 25.64% MySQL) with 10 queries
