Old 8th July 2011, 02:34 PM   #1
blo06 is offline blo06  France
Question SP200X MLTL
I got the MJK sheets and begin to dig in.
I understand a bit with the TQWL (the TL_Open_End_Corner sheet, right ?), and I wanted to make now a MLTL. (with the TL_ML_Corner )
With the TQWL, I begun with the alignement tables, so I have some numbers to begin with. But for a MLTL, is it some tables too ?
How to choose some numbers to begin (for L and S), that are not completly fancy ?
Thanks fo any answer.
Old 8th July 2011, 02:56 PM   #2
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Hi blo06,
I haven't answer you questions yet due to computer problems (my service provider DNS server have failed and been erratic since yesterday) but I have modeled your ML-TL in MJK:s program and will post as soon as possible (2-3 hours maybe).
I will then motivate in pictures (Post MJK:'s input screen) why a slim tall corner placed ML-TL is not a good choice for a sub using your driver...
.. I.e. you will notice a huge wide dip in the FR appearing(~55-150 Hz wide) making your sub quite difficult to use as f-3dB would be low.
Be patience
b
Old 8th July 2011, 05:06 PM   #3
Ok, I'm waiting !
Old 8th July 2011, 11:33 PM   #4
Jim Shearer's Avatar
I begin by designing a golden ratio BR cabinet. Using that box volume and port dimensions, I change the box to make it a MLTL. Run a model, then modify dimensions and run models until it looks good.
Cheers, Jim
A day without music is like a day without food.
Old 9th July 2011, 07:45 AM   #5
Jim,
thanks for the tip !
My TQWL experience with Monacor SP200X Gregje Full Range 1 2nd December 2010 08:34 PM
Monacor SP200X help! Rabbit Full Range 7 2nd July 2009 10:07 PM
need tips for monacor sp200x tyor Full Range 11 28th December 2007 01:48 PM
Mltl big_kahunah Full Range 2 31st August 2005 02:40 AM
Page generated in 0.07853 seconds (74.75% PHP - 25.25% MySQL) with 10 queries
