Would I gain anything??? - diyAudio
Old 6th July 2011, 12:45 PM   #1
sideways's Avatar
Default Would I gain anything???
Greetings!!!
So...running a pair of Hemp Acoustic FR4.5C's...in a vented box...now question...would I gain anything if I put them in an open baffle situation??
I am using dual subs with them crossed over at 80 hz with my miniDSP.
Thoughts??
Thanks kindly!!!
Old 6th July 2011, 01:53 PM   #2
Godzilla's Avatar
You will get a different presentation. You will not necesarrily 'gain' anything other than that. You may or may not like it better. The sound will be free from the box and the imaging will have a more floaty effect.
You might lose some mid bass warmth.
I have tried a few drivers on ob and sealed boxes with bass support and believe personal taste will determine which is better.
Old 6th July 2011, 02:07 PM   #3
It will cost you almost nothing to mount your speakers on 2 big cheap baffles and try them out, so go for it. You may need to adjust your subwoofer settings. If you're happy with the open baffle approach, then you can upgrade the baffle material to a nicer wood, or acryl or whatever.
Old 6th July 2011, 05:28 PM   #4
frugal-phile(tm)
planet10's Avatar
The XO will likely need to be quite a bit higher.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 6th July 2011, 08:08 PM   #5
sideways's Avatar
Well for one...losing mid bass warmth is a no go...love that!!! Even so, I guess it's super cheap to try LOL!!!
I would probably need to go to an 8" or even a 12" driver in order to keep the xover at 80hz no???
Thanks!!
Old 6th July 2011, 08:44 PM   #6
You can use minidsp to EQ the mids back, no?
Then again, what do I know?
Old 6th July 2011, 08:57 PM   #7
Hi, unless your baffles are massive you will lose bass response and SPL, rgds, sreten.
Small drivers are a very poor choice for open baffles and only subs.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 6th July 2011, 08:57 PM   #8
chrisb is offline chrisb  Canada
dave
Thanks!!
I think that Dave means to prevent excursion problems with the Hemps running OB, you'd want to XO the woofers at least a couple of octaves above 80Hz ( in stereo), and even then you could be limited in total SPL before they (Hemps) hit the wall
of course than means woofers with decent FR to at least 500-600 Hz for smoothest transition
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Transformer based voltage gain + unity gain stage? soundcheck Solid State 2 10th August 2010 02:44 PM
Throwing away open loop gain with an opamp near or at unity gain okapi Pass Labs 3 25th December 2009 01:23 PM
Gain Blockwith Variable Loop Gain Bonsai Solid State 17 11th July 2008 02:40 PM
Heretical Unity Gain line stage PLUS a little gain ? yagas Tubes / Valves 7 24th January 2006 01:30 PM
Unity Gain Operation (or low gain) Tomo Chip Amps 12 22nd January 2004 01:47 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
