VP cabinet like little larger speaker but have 4.5" Pioneer fullrange being idle in the garage. Like to follow Bob Brines cabinet as detailed here :https://mywebspace.wisc.edu/jstalnak...eakers/#Brines
He used a different driver (larger radioshack), A11 published specs are: , Power handling: 20 watts RMS/30 watts max * Voice coil diameter: 1" * Impedance: 8 ohms * Frequency response: 70-15,000 Hz * Magnet weight: 9.3 oz. * Fs: 70 Hz * SPL: 90 dB 1W/1m * Vas: .31 cu. ft. * Xmax: 1.1mm * Qms: 1.40 * Qes: .47 * Qts: .35 *, although GM noted published specs are unreliable. Would the cabinet size including the vent size as used by Mr. Brines reasonable for A11 drivers as a starting point?, (plan to leave side accessible for adjustment of stuffing and BSC circuit. Plan to add piezo with L=pad in the rear.l thanks in advance,
-- Good sound from Last edited by gychang; 3rd July 2011 at 03:46 AM. |
#2 | |
I don't have MathCad reinstalled yet, but at a glance it's almost as big as an unfolded BIB, so I'm thinking it's probably a poor fit overall unless driven with a ~matching impedance amp. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#3 |
wife likes the style of VP, t-amp clone or JVC hybrid amp (EX-A1) will be used. I am willing to make a larger VP cabinet...
-- Good sound from |
#4 |
I meant Bob's VP is theoretically much too large and tuned much too low for this driver and your amps if not loaded with a relatively large BLH. Indeed, it says that assuming a low system impedance, its lowest practical tuning [BH loaded], is this VP's ~45 Hz.
Bottom line, such a mismatch can always be EQ'd to work, it just may not play loud enough at a low enough distortion to be acceptable, so only one way to know for sure. GM
#5 |
thanks GM, your opinions are valuable to me. I have the original Merrill's driver (DCA4) for the zigmahornet (actually new, never used) in the garage. Don't have the specs however, wonder if this can be used in Bob Brines cabinet...
#6 | |
Bob |
#7 |
You're welcome!
Dunno, but if his drivers are scaled spec wise to maintain a similar 'tone', then with the DCA5.5 requiring ~2x the VP's net Vb and ~10 Hz lower tuning it might work well with minimal fine tuning, though of course without specs it's a crap-shoot. GM
#8 | |
My ultimate goal after I retire in few years is to put FE166en in your cabinet, but I will have to practice in other cabinets first.
| voigt pipe new design? | zycomatique | Full Range | 4 | 20th July 2010 06:00 PM |
| Voigt pipe as a TQWT | Keriwena | Multi-Way | 5 | 21st June 2010 10:17 AM |
| Voigt Pipe is looking for new home | mkapszewicz | Full Range | 9 | 21st December 2009 02:17 PM |
| Folded Voigt Pipe | Ropie | Full Range | 18 | 2nd November 2005 03:31 PM |
| MTM on a Voigt Pipe ? | johninCR | Full Range | 2 | 8th April 2005 06:20 AM |
| Page generated in 0.10502 seconds (74.65% PHP - 25.35% MySQL) with 11 queries |
