Just got a pair of FF225WK's
Old 2nd August 2011, 03:27 PM   #11
Bob Brines is offline Bob Brines  United States
Bob Brines's Avatar
Tom,
I like them. They have a nice smooth sound, particularly with a bit of DSP. Good bottom end, better than the FE207E. Lacking on the top. Once I get off of a couple of other projects, I intend to mate the 225WK with the FT17H.
(I have had very poor luck using a tweeter with a full-range running wide open. I am convinced that this will only work with a proper XO on both drivers. If I get lucky, I think that I can roll off the 225WK 3rd order with a single inductor. If not I do it a proper 2nd order XO ~6kHz. That is a comfortable place to cross the FT17H anyway and it is probably not too high to get a decent off-axis power bandwidth given that the FT17H is horn loaded.)
I have lived with the 225WK's for a while now and they do a credible job with most classical, jazz and girl-and-a-guitar. They work on classic rock up through Pink Floyd and the like. Much heavier and you shouldn't be running full-rangers anyway. With an Xmax of 2.25mm, there is plenty of room for bass EQ, so they sound pretty stout, although I brickwall them at 30Hz.
Give them a try!
Bob
Old 11th October 2011, 03:59 AM   #12
IG81 is offline IG81  Canada
IG81's Avatar
Bob Brines, anything to add or change to you impression of these drivers from ~2 months ago?
I also acquired a pair and got similar results for out of box parameters and response. Mine reside in Karlson "SK8".
They do quite well in there. HF is lacking though; I currently use some EQ at 20kHz and it helps nicely, but will look to implement a super-tweeter solution.
IG
Old 11th October 2011, 12:09 PM   #13
IG81's Avatar
IG
Mostly with regards to "break-in", if any, thanks.
IG
Old 11th October 2011, 04:35 PM   #14
Bob Brines's Avatar
IG
I never have thought that Fostex drivers take a lot of breaking-in. 100hr or so max. Maybe just me, but I think that longer break-in periods are more becoming comfortable with the sound.
Anyway, nice bass and mid-range. Definitely needs a tweeter, much more so than the FE207E. Because of the bump in the FR near 3kHz, an XO is a problem. I finally decided to let the 225 run wide open and cross an FT17H at 4kHz second order. Use a BSC filter and/or a zobel to contour things to your taste.
Bob
Old 11th October 2011, 05:13 PM   #15
IG81's Avatar
I heard about the FE series requireing a certain period of break-in, but never had these myself. I'll probably have to willingly drive the FF225WK hard in the Karlson to produce enough excursion to workout the suspension elements.
Regarding the ~3kHz bump, that's nothing next to the one on AD9710, inherent of it's straight-sided cone AFAIK.
IG
Old 11th February 2012, 05:43 AM   #16
jay53 is offline jay53  India
Originally Posted by Bob Brines View Post
Tom,
Give them a try!
Bob
Hi Bob,
I am building Metronome Speakers using Fostex 225WK & FT17H. Would appreciate hearing your experience on Cross Overs that you were contemplating of trying.
Thanks!
Jay
Old 28th March 2012, 12:25 PM   #17
Debaser is offline Debaser  United Kingdom
Hi Bob (or anyone else with suggestions),
I just built my first ever pair of speakers. The Ceinwyn Chang horn for the FE168EZ. Though they are still unsanded/unpainted I have listened to them with and without stuffing and I'm only moderately happy with the sound. They seem a but thin in the treble and with too much stuffing in the box they sound empty in the bass too.
If I remove all the stuffing from the box it actually sounds fine in the low and mid range but the treble still bothers me.
I have heard that the Fostex drivers can actually lack top end. Do you have any suggestions?
I'm thinking of adding a simple small dome tweeter and crossing it over around 3-4kHz or maybe even higher.
Cheers!
Old 28th March 2012, 12:51 PM   #18
Default Asian Ceinwyn Chang pics
Some photos of the ongoing Ceinwyn Chang build in Singapore
Old 28th March 2012, 01:16 PM   #19
Bob Brines's Avatar
Never had a 168ez. Most Fostex drivers can use a little help on top, but I would recommend against a dome tweeter. You should use a horn tweeter instead. Otherwise you will have a screwed up power response off axis.
Bob
Old 28th March 2012, 01:34 PM   #20
Thanks for the suggestion Bob. My friend whose workshop I've been using to build these said similar and swears by the coax horn tweeters in his Altec 604s (shown behind my Ceinwyns in the photo I posted.)
I'll do some more research before I buy something. Now I have the boring bit left to do. Sanding and painting.
Just got a pair of FF225WK'sHide this!Advertise here!
FS: pair of w3-871s drivers $35/pair norman bates Swap Meet 1 10th November 2008 08:51 AM
FS or trade 1 pair Dynavox 6.5" woofers, 1 pair of Tweets.. JCoffey Swap Meet 4 20th September 2006 04:56 PM
Pair of Jx92s and pair of Hemp FR8 for sale LizardBrain Full Range 3 11th September 2006 03:24 AM
My pair of Accuton C95-T6 for your pair of Seas W18E001 FrancoB Swap Meet 0 9th October 2005 08:23 PM
Good pair of speakers for <$200/pair? asauer Multi-Way 73 19th May 2004 10:47 AM
Copyright ©1999-2017 diyAudio
