I have some ported boxes of about 6 litres which house some FE127E's. I am looking to upgrade them to gain less 'shout' and better ability to handle LF in a home theatre surround application which in my mind means more xmax. I'm looking at drivers of a similar physical size so that I can use them without extensive surgery to the boxes. I've tabulated some options (attached) and this leads me to Mark Audio as the best choice.
As far as I can tell only the EL-70 is currently available. But it's 4 Ohm and I'd prefer 8 Ohm - although this may not be the deal-killer it once was as I'm sticking with SS amps for this application. The CHP/CHR-70 are similar drivers but with the promise of 8 Ohm. Question: what's the latest estimate for availability of CHP/CHR-70 drivers ? Question: with the EL-70 (or CHR-70), do you believe I'll achieve a worthwhile improvement over the FE127E in the areas I've mentioned above ? Thanks.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. Last edited by Bigun; 27th June 2011 at 10:05 PM. Reason: typo's |
#2 | |
some quick thoughts ( quick, not deep) Which channels of "surround" set up to you have in mind? Wouldn't the required bandwidth and X-max be far less for effects surrounds ( ie. rear / front height) than for the front row? As I've nattered about numerous times, my own little HT rig crosses over singles of Alpair7 in each of the front 3 channels at approx 110Hz to dual corner mounted woofers, and since my listening never reaches 105dB reference levels, I've yet to find this system's excursion limits. I'm even getting closer to fabrication a pair of corner / soffiit mounted enclosures for rear surrounds, which will utilize AP6Ms for timbre matching to the fronts. I think that's a very important factor to consider - and was the reason for choosing A7 for fronts - as good as they sound, the smallest enclosure in which it'll fit is still too large for my current furniture arrangement. Pensil7 001.jpg Pensil7 002.jpg The total volume of this room is approx 2500 ft^3 - and yes, there's still some work to do on the aesthetics of the set-up. The EL70 are still currently available either in stock form from Bob at CSS and treated from Dave. It's proven to be a great alternative to FE127E. 6 liters is quite on the small side for FE127E to achieve it's potential, but certainly within the comfort range of the EL70 ( see the mMarKel70) http://homepage.mac.com/tlinespeaker...map-231009.pdf I think any of the MA drivers would be a great choice for your application - while we've waited quite a few months for the newer Fostex offerings, and it's unlikely they'll present any major disappointments, the MA are already well proven, with a range of enclosure designs built.
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi Last edited by chrisb; 27th June 2011 at 10:29 PM. |
#3 | |||
hi Chris, that's a nice set-up you have there, nothing wrong with the aesthetics !
I've seen the cones on the rear surrounds moving way more than they should. I may have them XO'd too low. But with so much low end grunt available from the front I need better LF than the 127E's are giving me or the 'surround' is simply too 'thin'. The front centre FE127E does a nice job of the vocals, but it can be strained. Quote:
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. Last edited by Bigun; 28th June 2011 at 01:26 AM. |
#4 | |
frugal-phile(tm)
I was really hoping to see the CHBW take (and maybe extend) on the capabilities of the EL70 in the bottom, for use as a helper woofer with a CHP or A6.2, but the lobby that won turned it into a midbass not much different from the CHP. Box-wise the CHP70.3 seems to be closer to the new CHR70.3 than an evolution of the EL70+CHP70. A7.3 & CHBW it in a slightly smaller (optimum) box than the CHR/CHP. CHBW + ERT26 should be an interesting combo (XO somewhere around 5-6k) Don't expect any of the new drivers until the last half of July. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#5 |
To be honest, my experience regarding timbre matching in a surround system is so far only related to the front 3 row. In experimenting with different sized drivers by both Fostex ( ie, 167 L/R & 127 C) and MA (Alpair12 L/R and 7-C) I noted various degrees of timbral discontinuity, which did not occur with all 3 the same size.
How close you get to "cloning" the PMCs for rears is a very interesting question, better addressed by others.
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#6 |
Maybe this is off-topic, but how big a deal is timbral matching in your opinion - without some idea of how important it is makes it more difficult to know what else is worth trading off to achieve it ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#7 |
It may be a personal thing, but I find timbre matching very important. Having said that, it doesnt come up often. When a voice pans from left to right, it's AWFUL ( to me ) when the voice changes.
#8 |
frugal-phile(tm)
I'd suggest that no centre is better than a centre that doesn't match.
dave
#9 |
^ Does or doesn't ? You're agreeing I think.
To add, I find front to back less important. A lot less. Still prefered if possible. |
#10 |
frugal-phile(tm)
timbre matched centre v important.
dave
| Box for the FE127e | despotic931 | Full Range | 18 | 11th November 2008 12:46 AM |
| fe127e bipoles | Scribble | Full Range | 24 | 2nd November 2008 03:04 PM |
| Kofi Annan in: "Upgradin' the Table!" | Kofi Annan | Analogue Source | 10 | 18th August 2007 06:43 PM |
| working with the Fe127e | Roemhild | Full Range | 17 | 20th May 2006 07:41 PM |
| FE127E, Can I use this cabinet for them? | mbcy | Full Range | 7 | 13th February 2006 09:15 PM |
| Page generated in 0.14783 seconds (84.34% PHP - 15.66% MySQL) with 11 queries |
