Old 25th June 2011, 04:06 AM   #1
tuxedocivic's Avatar
Default I have two 3" FR drivers for use in FAST - which should I use
Hi guys,
I have a pair of Fountek FR88EXs and a pair of Tang Band of unidentifiable model number and serial numbers 1 and 2. I got them from Dave and P10. He says it's possible they were prototypes coming from the same source as the other set he raves about. Says he's had them for years. Anyways, given I don't have any info about them, but the Fountek is quite common, I wanted some feedback.
This was taken on an OB, 30 x 50 cm with rough edges (an old drawer) that could be causing some diffraction. The enclosure hasn't been designed, so those aren't the design dimensions. Ignore the bad null at 1620hz. They were 83cm off the ground, which by my calculations creates a null at 1640, so I'm sure that's what it is. The sensitivities are off, as I offset them for illustration. Bad measurement technique Green is TB, and red is Fountek.
Here is the impedance for the fountek:
And for the TB:
I think the TB looks cooler, and the assissting woofer is going to be closely matching in looks.
Old 25th June 2011, 04:21 AM   #2
ra7 is offline ra7  United States
Both your drivers appear to be following similar peaks and dips. Are you sure there were no reflecting surfaces near by? Those measurements look terrible and I doubt the actual drivers have this much variation.
Old 25th June 2011, 04:31 AM   #3
Well I admit they were quick and dirty, they are representative. The baffle had bad edges and the drivers were surface mounted. So diffraction will be bad. I just need to know which direction to go, so when quick and dirty. The floor is 83cm otherwise boundaries should be far enough away.
I compared the fountek to the manufacturers sheet and zaphs, and they have a common theme, dip at 8khz and such. The dip at 1620 should be ignored. I suppose the floor could be showing up elsewhere
Old 25th June 2011, 08:09 AM   #4
chris661's Avatar
If they're both of the same cut-out, why not listen and find out for yourself?
There's only so much we can say about the drivers. Which one sounds best to you, we can't say.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 25th June 2011, 01:40 PM   #5
I will listen to both once I build the cabs, but for now, I just wanted to know which one to focus the design on. I think the fountek looks flatter. Perhaps I should take better measurements and figure out a way to listen to them. I just thought one would look like a better choice, but I was shocked when they were so similar.
Old 25th June 2011, 04:55 PM   #6
frugal-phile(tm)
planet10's Avatar
Chris is right. Measurements qon't tell you about DDR or other subtle things the ear car pick out.
Don't get analysis paralysis
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 25th June 2011, 11:41 PM   #7
dave
What is DDR?
Davy Jones
Old 26th June 2011, 12:02 AM   #8
frugal-phile(tm)
planet10's Avatar
Downward dynamic range.
dave
Old 26th June 2011, 01:42 AM   #9
Well, I guess I'll make up some boxes or something. I think the fountek measures better, but thought maybe there was more to it, like diffraction, BSC, etc. I guess there was more to it... Listen!
Best <$50 FR for FAST wushuliu Full Range 5 5th November 2010 10:26 PM
Decent Cheap 6.5 " FR drivers. dpuopolo Full Range 3 16th September 2007 11:36 AM
FS: AudioNirvana 8" FR Drivers ervington Swap Meet 3 17th January 2007 02:48 PM
WTB: 269-469 ("1$ Parts Express") drivers, or other really cheap FR drivers. Spasticteapot Swap Meet 1 5th November 2006 03:31 PM
WTB FR drivers for "bigger is better" speakers. Spasticteapot Swap Meet 2 28th October 2006 08:08 PM
Page generated in 0.10280 seconds (81.06% PHP - 18.94% MySQL) with 10 queries
