Old 23rd June 2011, 04:21 PM   #1
Default Can I cheat on cabinet size with porting?
I have a full set of ATC drivers that I will never get around to making cabinets for. The 12" woofers I have are for SCM100 (100 litre cabinets) and I have a nice pair of 75 litre cabinets. The real SCM100 are ported using a 4" wide, 8" long pipe. Can I use some other size or an extra port to make the cabinet "act" bigger? Or do I need to just sell the drivers or build/find the right cabinets?
Old 23rd June 2011, 05:17 PM   #2
chrisb is offline chrisb  Canada
stuffing can help increase the virtual volume, changing net port dimensions could take the tuning in a misdirection
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 23rd June 2011, 05:36 PM   #3
Ron E is offline Ron E  United States
Ron E's Avatar
you can make it smaller, just make sure your new port tunes to about the same frequency.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 23rd June 2011, 06:07 PM   #4
Sub Box Polyester Fiberfill
If you fill it to the point where you get a 40% increase in volume size, then you'll get an effective volume of 105L from you 75L box.
Old 23rd June 2011, 09:50 PM   #5
18Hurts is online now 18Hurts  United States
You can put the ports external to the box
Ports take up internal space so it would work although the aesthetics are not WAF friendly. The other option is to install flat panel passive radiators instead of ports--tune the passive to smooth response in the final location the speaker.
I built a subwoofer out of an existing 3.5 cu ft cabinet, went with the passive radiator so I could easily tune it to it's corner location. Final tuning was 21.4 Hz and smooth...
Old 24th June 2011, 02:52 AM   #6
Is there a favored software for determining or predicting driver performance in differing enclosure volumes? If I were to go by trial and error using polyfill, would a test CD and Ratshack db meter get me pretty close to flat response? Needless to say, audio engineering is not my specialty...
Old 24th June 2011, 03:02 AM   #7
here's the simplest thing:
LinearTeam
you'll need some basic driver parameters...
Old 24th June 2011, 04:07 AM   #8
LinearTeam
what a mench!
Ekta Grande cabinet size? dublin78 Multi-Way 1 22nd July 2010 04:41 AM
SUPRAVOX 285 GMF cabinet size nirvana Full Range 7 26th January 2009 10:45 PM
Sealed sub: cabinet size?? Klimon Subwoofers 4 10th August 2006 11:26 AM
Need help with 5" midbass cabinet size andyjevans Multi-Way 6 5th November 2004 11:14 PM
Cabinet Size of Satelites ??? ralph-bway Multi-Way 2 29th October 2003 09:51 AM
Page generated in 0.09923 seconds (78.53% PHP - 21.47% MySQL) with 10 queries
