Old 18th July 2011, 10:47 PM   #21
This is looking really cool. I thought of doing something similar for a subwoofer. Being fat and fifty however I find bottom shelves almost useless so my plan was to have the horn or TL output at the bottom with a tasteful grill cloth cover. In my current house however I can use the attached garage for the bulk of the horn so I won't need to use that approach here.
Look forward to seeing your finished project.
If We The People refuse to hear the truth we will be ruled by liars.
Old 31st July 2011, 12:55 PM   #22
dhenryp is online now dhenryp  United States
Well, I've got one speaker complete (except for the bookcase part) and upstairs in my family room. It's pretty imposing in the flesh and in the living area. I've included a photo of the speaker in place in my family room. My wife is having some trouble imagining it as one of two nice looking bookcases in her family room. She's giving me a little bit of a stink eye. Time will tell.
I've only got the one built so my listening has been limited to one channel stereo and not much of that. It sounds good with with good bass. I will do more listening today and do some comparisons against my Pretty Big Horn from a couple years ago with the same FX120 driver.
I have made a lot of measurements with my Smith and Larson Speaker Tester. This is a great tool. I've included the measurements of the speaker as it stands now. It's pretty consistent with the simulations. I've made some significant design changes, but more on that in my next post.
Old 31st July 2011, 01:36 PM   #23
GM is offline GM  United States
GM's Avatar
Originally Posted by dhenryp View Post
Has anyone seen something similar?
Yes, though this is the only one I've seen on-line: retro vintage modern hi-fi: January 2011
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 31st July 2011, 01:37 PM   #24
Good reasons why a single good woofer is better than two. And going to two (or more) to control room resonances and still playing the same mixed bass signal, they should never be placed in the familiar symmetrical way anyways.
With the woofer up front, prolly no problem crossing over not far below 180 Hz. Which makes it easy to produce speakers to handle the rest.
A lot of people who never tried this (or didn't do it blind) will be outraged at the suggestion.
Dennesen ESL tweets, Dayton-Wright ESL (110-3200Hz), mixed-bass Klipschorn w/param EQ plus giant OB using 1960's Stephens woofer
HiFi aspirations since 1956
Old 31st July 2011, 02:18 PM   #25
Default Square coreners or curved corners?
My initial drawings show the internals with carefully curved folds that pretty faithfully implement the simulated expansion. I wanted to take the opportunity to make measurements to see if it was worth the effort in a back loaded horn. This topics has been the subject of numerous threads but I've not seen measurements.
Here are the arguments I've seen made:
For Square Corners - the only argument I've seen made is that the square corners in the folds will attenuate the mid range and highs while it would not significantly affect the lows because the wavelengths are too long (100 Hz has a wavelength of ~ 11 feet) to be affected. You don't want mids and highs making it out the moth of a back loaded horn because they will interact with the mids and highs from the front of the speaker with negative results.
For Round Corners - I've seen several arguments made for curved corners:
1. Square corners will affect the low frequencies and cause problems with the low frequency response at the mouth of the BLH. Curved corners will minimize this.
2. Curved corners will improve the efficiency of the BLH.
3. The square corners will reflect mids and highs back through the throat and to the back of the driver, affecting the direct output from the front of the driver.
4. Square corners will distort the sound coming from the horn.
I've got to confess, I was hoping that the curved expansion would have benefits or at least break even. I find the curves esthetically pleasing and I enjoyed the woodworking challenge of making them.
The Test:
My design has two folds; a 90 degree at the throat and a 180 degree fold at the floor. I built the speaker with both curved corners and square corners, see the attached picture. Everything else is exactly the same: the same driver and everything except the corners are unchanged.
I then made measurements of frequency response and distortion at both the mouth of the BLH and at the front of the speaker. I was very careful to keep the speaker positions exactly the same (against a wall, about 8 ft from a corner), the mike positions exactly the same, and the amplifier gain unchanged.
The Results:
The square corners performed better.
The graph comparing the response at the mouth shows nasty spikes at ~800, 1500 and 2000 Hz for the curved version. This surprised me since one of the arguments FOR the curves was that it wouldn't have this problem.
There is no difference in the bass level, so the curves didn't help that.
There is no overall lower level for the mids and highs with the square corners so, at least for my design, the square corners did not help this.
There was no difference in distortion at the mouth or at the listening position. Sorry, but I lost the graphs for this.
The responses on axis at 6' are virtually indistinguishable (see attached picture) but those spikes at the mouth can't be helping anything.
I'm moving forward with square corners. It kills me to do this but I'm an engineer and I have to go with what the numbers are telling me.
Old 31st July 2011, 02:45 PM   #26
Default Other measurements
I've attached a picture showing the response with fiber fill and another showing where the fill went. It made a pretty substantial improvement and I'm going to keep it, though there is a chance I'll experiment some more with placement and amount. The main detriment to experimentation is that there are about 30 screws holding on the back and it's a pain to take it off and put it back on.
I said it has good bass and I've attached graphs comparing the bass output, at the mouth and on axis at 6', for the Bookcase Horn and my Pretty Big Horn w/FX120 and my Little Big Horn w/FE126 from a couple years ago. Depending on which graph you look at, The Bookcase Horn picks up 20-25 Hz on the low end.
One final note on the various charts showing response on axis at 6': The bass response is very dependent on speaker position and mike position. To some extent, I'm measuring the room as much as the speakers. Once I started taking measurements I was locked into both speaker and mike positions because I wanted all the measurements to be comparable.
Old 31st July 2011, 03:25 PM   #27
GM's Avatar
These are most likely mouth termination issues that can be dealt with by edge damping. The curves just facilitated them getting back to modulate the throat much more efficiently.
Hmm, the square corners did lower the level over a wide BW Vs the curved horn had it been 'ideal', but being truncated, only over a relatively narrow BW. By comparison, the various early W.E. horn's gain BW is so wide/efficient that the driver designed for them doesn't have a rear cover per se to keep its output from audibly comb filtering with its mouth output, only a bug screen/~aperiodic cooling vent to roll it off a bit more [for scale, those are 18" woofers]:
GM
Old 31st July 2011, 03:45 PM   #28
GM - you are right, of course, that in the range of the spikes the square edge version has a lower output. I was thinking of the spikes as a separate issue, not directly related to the reduction of mids/highs.
Where would I put the edge damping? At the edges of the mouth or the throat? What would you suggest I damp it with?
Old 1st August 2011, 06:18 AM   #29
GM's Avatar
Normally one would fold it over the mouth rim ala Peavey, but for a bass horn it could be just on the inner 'lip' and extend up/down from the edge some distance, though not sure how much since my way of dealing with it is to 'kill two birds with one stone' by making a vent screen lined with 1" fiberglass acoustic insulation.
No clue what density open cell foam is required, I just know that what I use is good down to ~250 Hz, making it almost overkill for damping Altec 800 Hz cast alum. horns when used down to 800 Hz: http://www.lansingheritage.org/image...iago/page2.jpg
GM
Old 2nd August 2011, 12:02 PM   #30
Now this is a good thread! Excellent work so far! Amazing.
I can't wait to see the finished bookshelf version. Will finishing the bookcase change the WAF "stink eye" into an approving grunt? I can't wait to find out.
I applaud you sir!
BLH Cab minhaj Full Range 6 2nd May 2011 04:09 AM
Chambersize in a BLH Bkaasen Full Range 12 25th January 2011 04:57 PM
Big Toroids & Big Caps K-amps Swap Meet 10 25th June 2009 07:43 PM
BLH of LE8T cominup Full Range 4 24th November 2006 07:45 AM
Having problems with port size... how big is far too big? fjhuerta Multi-Way 10 30th August 2005 06:20 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
