Old 5th June 2011, 08:00 AM   #1
Default Ringing in Philips 9710
I am using Philips 9710 in an tqwt enclosure.
I have noticed that one driver produces sometimes a high pitch ringing.
This happens usually when playing sopranos (in loud passges) or some guitar notes.
This does not happen when played quietly. Still annoying when you want to turn up the volume a bit to get more like life like performance.
It is still there when I take the driver out of the enclosure.
Is the spreaker fried? I guess there is nothing I can do?
Any hints will be appreciated.
Greg
Old 5th June 2011, 08:40 AM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
if Rdc is comparable with other driver - VC is probably fine , and then all you need is to realign it .
find good speaker repair shop , for them it's piece of cake
in any case - only after complete disassembling is possible to be sure
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 5th June 2011, 09:52 AM   #3
Yes, Rdc seems to be ok.
Thanks for the advice.
Greg
Old 7th June 2011, 12:50 PM   #4
I googled around to find a good workshop in the UK (preferably London).
I can't find anything.
Any clues, good/bad experience?
Old 8th June 2011, 01:49 PM   #5
DrBoar is offline DrBoar  Sweden
Try first to figure out what the reason is.
If you swap positions for left and right speaker. Does the ringing follow the driver?
No= room accoustics
Yes= try swapping amplifer chanels without moving speakers. Does the ringing change with swapping?
No= Driver problem
Yes= amp problem
If driver problem is it coil or cone.
Try putting a doughnut of cotton or some other BAF or soft foam betwwen the inner cone and the main cone. Production tolerances can cause several resonances to coincide in one driver but not others, if you are out of luck.
Scraping voicecoil can be detetected by playing something like the 0-200 Hz test tone ( download from the net) and playing at a low volume with the driver out of the box. Out of the box the ideal driver would not make any noise at all just vibrate wih very little extra sounds being emitted.
Realigning a cone with paper suspension without reconing it?
I would look out for 9710 in flea markets and Ebay. I got a pair on a flea market for about 20 euros, in Voigt pipes facing forward and sounding quite terrible. The driver is made for facing upwards not towards the listerner
Old 10th June 2011, 08:11 PM   #6
I tried the speakers with a different amp.
The problem is still there. Also when I took out the drivers from the enclosure.
Still have to try teh damping between the cone and the whizzer as you suggested.
Old 14th June 2011, 08:56 PM   #7
I have tested the driver with the tone generator. It resonates at 1370-1420Hz.
Is this the voice coil then?
FS: 14 x Philips Speaker: 1265/W8 + 1265/M8 + 9710/M8 jdkwant Swap Meet 0 11th November 2010 07:17 PM
Cabinet Plans for 9710 and Bombardon Vathek Multi-Way 14 8th October 2010 09:15 AM
Question about bass driver in combination with Philips 9710? bezobraznia Multi-Way 3 13th December 2008 07:15 AM
Fostex FE206E or Philips AD 9710 M8 69122s Full Range 14 6th December 2007 09:29 AM
Acoustic ringing? grataku Solid State 1 15th March 2001 04:55 AM
Page generated in 0.09307 seconds (75.99% PHP - 24.01% MySQL) with 10 queries
