Old 4th June 2011, 07:01 PM   #1
gychang is offline gychang  United States
Default B20 in open baffle, help needed
I have the plywood cut the opening but realize the size needs to be changed, besides the Pioneer B20s, I also have piezo tweeters and L-pads laying around. Would science oriented folks here help me out to get the better sound?
Is there a reasonable size of the baffle I should shoot for? (size now is 24"x16"), I can certainly add more width.
Should I need to add electronics to my L-pad (various resistors I have laying around)
I realize the bass will suffer in open baffle, I will be driving these in a smallish room with my Pioneer Elite HT receiver.
gychang
Good sound from Phoenix, AZ
Old 4th June 2011, 09:28 PM   #2
bigdh31 is offline bigdh31  United States
There are two things that are going to limit the bass response of your current configuration. The baffle is a little small and the driver has a moderate QTS. If you paired these with a sub-woofer it might work well. The fun of DIY is trying different things. You might like the baffle just as it is.
Getting good ob bass usually involves larger baffles and larger drivers with QTS values approaching 1.
See MJ Kings excellent site "www.quarter-wave.com" for good info on ob design.
There are many references on connecting a pizo tweeter that you can find with google.
Old 4th June 2011, 09:51 PM   #3
Pano is offline Pano  United States
Pano's Avatar
Please see this thread: Pictures -- Why Not attach Them ??
I have fixed it.
Old 5th June 2011, 01:03 AM   #4
I have fixed it.
thanks,
Old 5th June 2011, 01:53 AM   #5
GM is offline GM  United States
GM's Avatar
The B20 has a ~171 Hz mass corner which ignoring any near boundary gain equates to a ~36" wide baffle. Put an 8 ohm non inductive wire wound power resistor in series and it drops to ~100 Hz with a ~61" wide baffle. Of course as you move them back into corners they can be reduced in width, though at some point they start sounding a bit 'boxy' if you don't toss a big roll of insulation in the corner.
You'll need an XO for the piezo along with the 'L' pad. Godzilla has considerable experience with this combo, so check out what he's done.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 5th June 2011, 02:00 AM   #6
The one and only
Nelson Pass's Avatar
You probably should go as wide and high as you can. I've had good results
with 36"w x 72"h, but I've also been able to get away with 24w X 48h,
especially if you don't mind a little bass eq.
Old 5th June 2011, 02:47 AM   #7
does it have to be flat?, can the baffle be bent back a little...
Old 5th June 2011, 03:07 AM   #8
Pano's Avatar
Wings can help.
Old 5th June 2011, 03:15 AM   #9
Wings can help.
I was wondering if the size of wings can be included in the baffle size calculations.
Old 5th June 2011, 03:18 AM   #10
Pano's Avatar
Kinda, sorta. They don't count 100%, tho.
Pioneer B20 open baffle -- popular tweeter jmar Full Range 22 24th June 2011 01:27 PM
Help needed with open baffle project juliopr Multi-Way 3 13th March 2010 10:03 PM
Open Baffle Size for Pioneer B20 repeddler Full Range 14 15th February 2010 05:24 PM
B20 on Open Baffle Godzilla Vendor's Bazaar 16 24th January 2010 07:24 PM
Fostex FE167E Help with open baffle needed jmillerdoc Full Range 4 8th December 2009 03:20 PM
Page generated in 0.11524 seconds (76.01% PHP - 23.99% MySQL) with 11 queries
