Old 31st May 2011, 09:18 PM   #1
Default SPL gets higher?
A question from a complete beginner. If I buy, lets say a full range driver of 89 dB (no particular brand or type), and I put it a horn-cabinet (frugal or else); will the real SPL of the speaker be higher? If so, what is the expected gain in dB?
Old 31st May 2011, 09:29 PM   #2
picowallspeaker's Avatar
Any kind of cabinet will do that . What ? To prevent the back emission of the speaker to 'collide' with the front wave (acoustic short-circuit ).
If the cabinet is provided with some port ,the sum of the driver + port will be major if they are in phase .
This happens also with horns .
Old 31st May 2011, 09:39 PM   #3
yes, I 've been looking around to find an DIY enclosure en driver, proven "excellent" , but about 103 db SPL because I use a 13 Watt T-amp (8 ohm). So, i need to know approx what gain (in dB) to expect.
I would like to build an Horn, single driver. Cost en difficulty woodskill, are no problem.
Old 31st May 2011, 09:53 PM   #4
tinitus is offline tinitus  Europe
frugal is backloaded
it will only give gain in bass, and maybe some midbass
about 90db it is
Old 31st May 2011, 10:06 PM   #5
No single driver ,sorry
The magic word is ' differentiation'
Happens also with humans ,you know , male-female ...
Once the driver (woofer ) has some acoustic load , it works on its specific bandwidth , so the woofer has to move lot of air . It 's his job ,and also the enclosure , which also supports the tweeter ,which has to be phisically near the woofer ; the tweeter makes also vibrate the air ,but at higher speed (frequency) . To get reasonable SPL ...those drivers need to be very good .
The only thing that comes to my mind is the Econowave project , which is a tipical PA style speaker ,with a big and efficient woofer (not in horn enclosure ,too keep also space...efficient) and a compression driver as a tweeter.
Compression driver needs a horn...so you're done !!!
Old 31st May 2011, 10:18 PM   #6
chris661's Avatar
A horn will make a driver more efficient in its operating range.
For example, I have a pair of tapped horns. The same drivers in a sealed box would be of <70dB@1w for the frequencies I use them for. The tapped horns are at more like 85dB.
To increase the entire SPL curve, you'll need either a very large front loaded horn (like a big compression driver), or a combination of front and back horn loading of the same driver. There are few examples of this: a tribute to the sheer difficulty of such a thing.
Good luck,
Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 1st June 2011, 05:31 AM   #7
What I'm searching for is indeed not yet to find, lots of designers say A&B about the concept but not "C" - the figures of SPL by example.
I considered, buy an T-path modules of ca. 300watt (4ohm) and make active enclosures with a good broadband driver.
However, help me with finding excellent broadband drivers (for horn designs) with high (+95 dB) figures please.
WTB: 10,000uf or higher 71V or higher caps, max 30mmD KevinLee Swap Meet 1 10th December 2009 12:39 AM
SPL@2.83V or SPL@1W ? what is right? Astro Power Subwoofers 6 29th December 2005 10:58 AM
Is it true that the higher the BL of a subwoofer, the higher its lowest playable... 454Casull Subwoofers 16 19th March 2004 04:28 PM
Flying higher and higher with the Doede Dac Lucas_G Digital Source 139 27th February 2004 06:40 AM
Super-power amps - higher current better than higher voltage Circlotron Solid State 34 28th June 2002 04:01 AM
Page generated in 0.10229 seconds (75.09% PHP - 24.91% MySQL) with 10 queries
