pics of first build plus initial observations
Old 30th May 2011, 09:54 PM   #1
chazdrumzalot is offline chazdrumzalot  United States
Default pics of first build plus initial observations
I just finished my first build: a 25L dual chamber bass reflex for the W5-1611. After playing around with Jeff Bagby's baffle/room simulator, and using the flat 5 design as a starting point, I eventually built a cabinet with a 20" wide baffle. I hoped to push the baffle step down to where boundary effects boost the sound anyway.
My carpenter friend advised me as I left, "don't plug them in until you've applied the finish, or it will never get done!" Oh well. Naturally I couldn't wait to go through that trouble so I threw some damping in and ran the wires through the port. This is the first time I've gotten to hear the W5s running full range without a sub. So far the sound is as I'd hoped. To me the sound appears quite balanced, although I can hear some resonances which show through on piano recordings most. Bass and dynamics are sufficient for most music, but I'm still planning to add some 1 ohm resistors and see if I can't get them down to 40hz as was recommended by Hobby Hi-Fi. As of now they cannot produce the lowest notes on some of the electronica i tested them with, nor do they even seem inclined to try. But overall I expect these speakers to sound their best on small ensemble acoustic music and jazz where big dynamics and deep bass are not all-important.
I learned a lot about good cabinet making with this project, most notably that making a good cabinet is time consuming! Also, apple ply is expensive stuff.
Old 31st May 2011, 01:29 AM   #2
ultrakaz is online now ultrakaz  United States
Congratulations. Great build! Now that is a purist "full range" speaker. No sub, no added tweet and no correction filter. Wide baffle to address the baffle step loss and double reflex to extend the bass. Tweek slowly and enjoy the process and more importantly the music.
Old 31st May 2011, 01:57 AM   #3
Godzilla is offline Godzilla  United States
Godzilla's Avatar
They look very nice. I think other's have commented on resonances with different drivers in double reflex designs. If your intention is to use a sub one day perhaps a simpler, smaller ported box might work better and without the resonances you currently hear. Enjoy them! Btw, i have tried many boxes with the same driver over the years. It's part of getting a better understanding how different cabinets contribute to the overall sound... dbr, bh, ob, ported, sealed... tqwt... the list goes on!
Zilla
Old 31st May 2011, 04:05 AM   #4
norman bates is online now norman bates  United States
norman bates's Avatar
nice, i like the baffle is wider than the enclosure.
Old 31st May 2011, 04:41 AM   #5
Thanks Ultrakaz, that was the point entirely!
Zilla, the resonances I refer to are rather high up the audio spectrum so I doubt they are attributable to the ports; but are they a result of the cabinet walls or the driver? I'm not yet sure. (The cabinet is not at all large and it has two horizontal braces.)
At this point I've lined the walls with a combination of egg crate foam and 5/8" foam from madisound, and even added a bit of acousta-stuf. After completing the damping and starting up one speaker by itself, I get the impression that the bass has deepened somewhat. I honestly doubt that I'll experiment much with the damping at this point.
Old 31st May 2011, 04:45 AM   #6
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
Hi ,
I'm not sure if the (eggcrate) foam needs to be in place on the front baffle ( behind ..of course !!)
Old 31st May 2011, 05:00 AM   #7
grindstone is offline grindstone  United States
grindstone's Avatar
congrats and nice work. not sure but i'm thinking your drivers are still floating? that will change the bottom (and maybe the resonance character) a bit, too, after you get done
Old 31st May 2011, 05:45 AM   #8
Yes, they're still floating (merely taped), and the back is still unsealed! So I suppose the sound I'm getting now is still quite compromised. I intend to buy some blu tack to seal the driver and the back to the cabinet and make it air-tight. But before I glue down the damping, seal the cab, and install the binding posts, I gotta finish the damn thing! Oof...I hate waiting.
Old 31st May 2011, 11:47 AM   #9
zman01 is offline zman01  Bangladesh
Congrats on your build!
So Chaz, when are you going to say "Speaker hoye geche"?
-Zia
Old 31st May 2011, 12:02 PM   #10
GM is offline GM  United States
GM's Avatar
Any leaks in vented cabs, especially multiple resonant chamber alignments, pretty much totally ruins the tuning [raises Fb], so adjusting damping is generally a waste of time and will tend to be over-damped once the cab is sealed up. Also, just taping in a driver adds a major extra loss of acoustic efficiency, further over-damping the system, so little wonder there's no bass to speak of.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
pics of first build plus initial observationsHide this!Advertise here!
Super Pensil Build with Pics zman01 Planet 10 hifi 38 9th July 2011 06:23 AM
Pics of a UcD180 build for my son... ptwining Class D 2 6th March 2011 09:08 PM
New Aksa Amplifier build pics - Naksa jkeny Solid State 48 21st July 2010 08:09 PM
New Build Pics (guitar Amp) Trout Instruments and Amps 15 20th November 2006 08:21 PM
Want to build a horn box for my JBLs (Pics!!!) Zac_cutt Subwoofers 17 29th May 2006 11:45 PM
Copyright ©1999-2017 diyAudio
