diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Full Range (http://www.diyaudio.com/forums/full-range/)
-   -   FaitalPRO 3FE20 sensitivity? (http://www.diyaudio.com/forums/full-range/189614-faitalpro-3fe20-sensitivity.html)
BHTX 24th May 2011 08:45 PM
Been looking at 3-4" full range drivers. It'd be used in a small 3 way with separate woofers (so 4-way really), all simple 1st order electrical, attempting to meet a 1st order acoustic as far as possible (around 100, 1k, and 10khz).
The FaitalPRO 3FE20 and 4FE30 caught my eye a while back, but I'm very suspicious of the 3FE20's sensitivity rating. IIRC, the last time I modeled it, sensitivity from T-S parameters yielded around 86 dB/watt. Looking at the graph on their website, it does indeed reach 91 dB. So, does it have a rising response characteristic? Or, are they really just cheating as badly as Monacor (and others) by lying about both the sensitivity spec AND manipulating the graph to show it? I figure it must be one of the two. If it's the former, I could deal with that. If it's the latter, I'll scratch it off my list.
I'd be really interested in hearing from anyone who has used this driver and any measurements they might have.
FaitalPRO - Professional Loudspeakers Made in Italy
Scottmoose 24th May 2011 09:25 PM
Calculating from their T/S specs. (several of which look rather too pat to be entirely believable IMO) you're looking at a reference efficiency of 0.28% & a sensitivity figure of 86.49dB 1m/w, or 87.6dB 1m/2.83v.
Manufacturers often take an average figure for the SPL (some pick the highest point, even if it's a major breakup), so make of that what you will. Personally, I'd always err on the side of caution.
freddi 6th October 2011 09:35 PM
I've got a 4FE30 in a mini-Karlson - am breaking it in on a Jimmy Witherspoon DVD-A - meters peak around -12 or do at a decent level with 0 = 375 watts into an 8 ohm load - for this type driver and the coated cone, it has good HF - I want to loosen it up but don't wanna cook the tiny coil - these meters are really crappy - its more like -17dB peaks at a good level for blues listening
freddi 8th October 2011 05:03 AM
subjectively (in A-B comparison), 4FE30 in a mini-Karlson is a good deal punchier, louder and better extended on top than the MCM 5" monitor (~like Dayton's PA130) mounted in a paper mache "reflex-head" in A-B. 4FE30 might be worth consideration. They sell for $32usd each.
freddi 8th October 2011 07:07 AM
http://img534.imageshack.us/img534/1...aital4fe30.jpg
BHTX 8th October 2011 10:18 AM
Nice. Thanks for the info freddi!
ears4hire58 27th September 2012 01:59 AM
Yes the 3Fe20 are >90dB. We did use the 3Fe20 as MF in a 3-way system with good results (& are liquidating several of these 3" Nd drivers).
IG81 27th September 2012 01:50 PM
I forget if you have it or if JL kept it, but do you have an FF125K? How would you compare the sound versus 4FE30?
IG
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
