Help with Converting These to Full Range SET Type
Old 24th May 2011, 12:42 PM   #1
scm is offline scm  United States
Default Help with Converting These to Full Range SET Type
Gentlemen..I want to try the low power SET type system.
What I`d like to do is use these speakers.
I actually bought these new back in '84 or so from a small shop in Ottawa called Euphonics.
They are Dayton Wright XAM-4`s. I cut the fabric back to show the drivers.
The lower section is a sealed section with a 10" woofer.
The top section has the mids and tweeters with an ambiance driver on the top back.
They can be Tri-amped via the connections in back.
48" High 11" Wide 16" Depth on the lower section.
I`d like ask you builders what you would use/do to use these with a Sophia Baby tube amp with 10 Watts.
I`m thinking a ZU or Tekton type of set up.
Steve
Old 24th May 2011, 06:51 PM   #2
chrisb is offline chrisb
Pure conjecture on my part, but based on your description, this is a 4 system in which one would expect a XO network that might well have a higher parts count than some of the SET amps I've owned /built -- it wouldn't be hard to imagine many SETS not playing happiest into that complex a reactive load.
I'd suggest that while raw horsepower may not be necessary (15-20W?), a P/P amp with feedback might better serve the music with these. Assuming that you've been playing them for at least part of the 27yrs since you bought them, what amp(s) have you liked them with the most?
kinda burnt out - taking a break
Old 24th May 2011, 10:12 PM   #3
Hi Chris. Actually, I think I should have asked something like this :
" Hey Guy`s can I load these speakers cabinets/boxes with SET type
90-110 DB high efficiency drivers ?"
Really just start from scratch just using the box is my idea.
Is there any problem with the angled top ? I seem to see most SET type speakers ZU and Tekton etc are plain boxes with no slope.
I`d like to finish them in Piano black to mach my Rythmik sub that is if I can do this.
Old 25th May 2011, 02:29 AM   #4
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
I think you should just start from scratch period! And, piano black is probably THE most labour intensive finish. I'm assuming you aren't going to be the one building and finishing the boxes?
jeff
Old 25th May 2011, 11:17 AM   #5
Hi Jeff. The piano black idea doesn`t put me off, I`m pretty sure I can handle that.
The speakers themselves are solidly made. Why build boxes when I already have these ?
Old 25th May 2011, 01:46 PM   #6
GM is offline GM  United States
GM's Avatar
" Hey Guy`s can I load these speakers cabinets/boxes with SET type 90-110 DB high efficiency drivers ?"
Yes.
Depends on what drivers you choose. A strong rising on axis driver such as a Lowther could work when seated, though of course it would 'tear your head off' if roaming around the room.
In the LF, HE woofers tend to need large cabs to go low, so depending on how high an output impedance you choose could make the lower part of the cab too small much in the way of bass output.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 25th May 2011, 02:54 PM   #7
I do have a 12" driver Rythmik sub that I use for MMG`s.
So what idea`s can you come up with ?
Seriously new on this stuff.
It has a 10" Eminence in the bottom section now. What about a 10" 97db 8 ohm type full range in there then whatever might work for the top section ?
Old 25th May 2011, 05:34 PM   #8
Frankly, I think you'd be better off starting from scratch.
By the time you sort out finding FR drivers that would deliver the type of performance that you're probably used to, or find acceptable, within the confines of the existing enclosures, and preparing the boxes for a piano grade finish (Jeff is correct - although gloss white is probably as much of a bitch to get right as black), I think you'd be second guessing the undertaking.
Don't get me wrong, I'm as big a fan andcheerleader for single driver / SET systems as the next guy, (just search "all posts by" ) and have built more than a few labour intensive enclosures over the years, but making a silk purse out of this particular enclosure would not be something I'd consider.
All that said, if you do decide to proceed, you should probably try auditioning at least a few FR type systems to test where your tastes lie. Not all FR/SD systems sound the same, and as very little research here or at any other forums will reveal, all types have advocates and detractors.
These will not be the easiest to find in remaining bricks 'n mortar shops, but presumably there would be some enthusiasts within easy driving distance.
Old 25th May 2011, 10:40 PM   #9
vinylkid58's Avatar
I don't care how well made they are, those boxes are seriously aesthetically challenged! I think it's time to move on and build something a little more current. How about Alpair 10.2 Pensils, imagine them in piano black:
http://www.diyaudio.com/forums/marka...00b-bravo.html
jeff
Old 26th May 2011, 03:39 AM   #10
Greg B is offline Greg B  United States
I'll go against the tide here and say try them as is. If it's to dynamically challenged, biamp using a bigger amp on the woofer section.
I will strongly agree that retrofitting these into some sort of multi way full range system is a huge mistake. You will not learn speaker design that quickly. A simple scratch built project with a single full range driver is a much better bet.
AFA aesthetics, piano black on something that large requires spray equipment. To do it correctly takes about 15+ coats of lacquer, hours of labor, and years of practice. An easier approach would be to recover with gloss black vinyl and make some new grills.
Help with Converting These to Full Range SET TypeHide this!Advertise here!
FS: FOSTER Full-Range Set (FE-103oid) speaker Swap Meet 12 28th June 2011 05:02 AM
Korean Sonodyne S-654 Full-Range/Wide-Range Drivers thetubeguy1954 Full Range 6 18th January 2011 10:42 PM
Frequency range of the human voice & full range center channel speakers jwmbro Multi-Way 31 20th January 2008 03:07 PM
need help on info on DUAL type 260283 10" Full Range Coaxial (german made) eestrera Full Range 1 2nd November 2006 01:28 PM
Copyright ©1999-2017 diyAudio
