diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Full Range (http://www.diyaudio.com/forums/full-range/)
-   -   Mark audio paper drivers vs tang band and fostex. (http://www.diyaudio.com/forums/full-range/189474-mark-audio-paper-drivers-vs-tang-band-fostex.html)
phil09 22nd May 2011 05:28 PM
Hello all again. I have been doing some research and I am looking to build for my self a little fullrange tower. I just finished the room I will be useing.
I have had alot of fullrange drivers but, I have never heard the mark audios drivers. The model I am looking at is the Alpire 6p gen. 2. For a 3 1/2 driver $54.00 each is alot but, are they worth it next to fostex or tang band or any other compnay.:confused: This driver would be used for movies music. I am looking for a driver with very clear and low level details.:D Please let me know what you think or were to go? Thanks jm
planet10 22nd May 2011 07:02 PM
I would consider the Alpairs to be amoungst the high end of 3" drivers. Fostex dicontinuedthe only 3" that would give it a run (FF85 -- Mark has a pair of my uFonkeb, with the challenge to make the new gen A6 better). The only pair of really impressive TB 3 inchers i've run across, likely never got further than serial #1/2 that i have.
A tier down from the A6, and above most of the rest, is the Fountek FR88ex.
dave
talaerts 22nd May 2011 10:05 PM
For movies you'll definitely want to add a subwoofer.
DYNABLASTERTUNERS 23rd May 2011 01:14 AM
planet10 you really have to listen to those new Tang Band flat cone 3", and your point of view will not be the same again! but of course in FAST arrangement (crossover f. about 400Hz or higher- depends on how loud you listen)
also please read this;)
6moons audio reviews: Boenicke Audio SLS
planet10 23rd May 2011 01:44 AM
400 Hz XO is to high for my taste.
One TB at a time, My 1611 are on order.
dave
phil09 23rd May 2011 06:42 PM
Well that is good to know that the a6s are very high end. I am going to get a sub to run the lower octives. Thanks again jm:D
phil09 23rd May 2011 06:45 PM
Originally Posted by planet10 (http://www.diyaudio.com/forums/showthread.php?p=2580337#post2580337)
dave
Hay dave have you tried the A6's next to the Fountek Fr 88ex's ? How about the tang bands never got futher then the serial # 1/2 that I have:scratch: Please do tell.:D
planet10 23rd May 2011 07:17 PM
I've not had the oppertunity yet to try my A6.2. I have thou listened to a very early A6P (many enhancements in the actual production units) and i prefer it to FR88ex.
http://www.diyaudio.com/forums/full-...tangbands.html
dave
mondogenerator 24th May 2011 04:37 AM
Originally Posted by planet10 (http://www.diyaudio.com/forums/showthread.php?p=2580631#post2580631)
dave
HAhaha you picked a good TB to mess with
planet10 24th May 2011 04:43 AM
Originally Posted by mondogenerator (http://www.diyaudio.com/forums/showthread.php?p=2581782#post2581782)
Already had 1772 & 1808 thru here, i'll pass on those for my own use (but happy to tweak them up for others)
dave
Copyright 1999-2017 diyAudio
