diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Full Range (http://www.diyaudio.com/forums/full-range/)
-   -   Alpair 7 with loose magnet... (http://www.diyaudio.com/forums/full-range/188519-alpair-7-loose-magnet.html)
pauldune 6th May 2011 02:33 PM
1 Attachment(s)
Today I received my new ordered alpair 7's from Europe Audio.
When I opened the box I saw that one of the speakers had a loose 2nd magnet.
My question:
Can I glue the magnet back on myself, (what type of glue?) or do I have to return them?
greetings, Paul
Cal Weldon 6th May 2011 02:40 PM
Yes you can reglue it but it's a little tricky. I would use epoxy and a vice. Remember you have to have the magnet with opposing polarity so it's likely to be a two person job. If the magnet came off it probably took quite a jolt so you might want to make sure everything else is ok and that the original glue job was a weak link. Also look into surface prep before you attempt to glue.
pauldune 6th May 2011 02:50 PM
Hey Cal,
Its not opposing polarity; it snaps right into place if I put it back on. I'm sure thats how it's supposed to be, because the cap is still glued to the second magnet.
Also, I'm not so shure about placing a driver made out of plastic in a vice..
greetings, Paul
markaudio 6th May 2011 03:23 PM
Hi Paul,
My apologies for this problem. Cal is wrong, there's a quick simple fix.
1 - Use a wire brush to roughen both contact surfaces. You only need to brush for a minute or so. Wipe clean with a soft dry cloth.
2 - Apply a good quality epoxy glue to both surfaces and gently press together. The magnetic tension will do the rest (Don't use a vice as Cal suggests).
This method will make the fix and the driver will perform normally.
Mark.
Cal Weldon 6th May 2011 03:35 PM
Sorry Mark, not trying to interfere here but I am confused. It's not a bucking magnet? If that's the case, I apologize, the vice is for bucking magnets and should be used with the driver mounted to a temporary baffle and of course protection on the rear. Hence the two persons.
markaudio 6th May 2011 03:45 PM
Originally Posted by Cal Weldon (http://www.diyaudio.com/forums/showthread.php?p=2563660#post2563660)
Sorry Mark, not trying to interfere here but I am confused. It's not a bucking magnet? If that's the case, I apologize, the vice is for bucking magnets and should be used with the driver mounted to a temporary baffle.
Hi Cal, no worries,
The Alps have attracting magnet systems so its an easy fix (no vice needed). I am contemplating using no glue on this section, giving the guys the choice of non-sheilding or partial shielding. The potential advantage of the non-shield is a slight increase in SPL as the drive-train electrical damping changes; And there's less mass behind the cone inside the box.
The new batch of Alpair 7's have retaining guide lugs built-in to the back of the frame mount so this method is easily possible. More on this when I announce the latest Alp7 in the next week or so.
I'm already running a prototype unit with this option. I'd need to do more testing on this to make sure other performance factors remain stable.
Cheers
Mark.
Scottmoose 6th May 2011 03:49 PM
Useful to know. Cheers Mark.
Cal Weldon 6th May 2011 07:26 PM
Yes, thanks Mark.
jimbro 6th May 2011 08:04 PM
You might to cover the cone with something while brushing and gluing to protect it from what I call "Jims".
pauldune 6th May 2011 08:17 PM
Mark, thanks for the method. I will fix it myself then, no need to send it back.
As to other damage: I can see none. Wonder why it came loose....
Greetings, Paul
Ps. Diyaudio is a amazing place! Where else can you get advice from the man who designed and created the speaker?
Copyright 1999-2017 diyAudio
