Old 5th May 2011, 01:32 AM   #1
60ndown is offline 60ndown  United States
Default 8" dual 4 ohm DVC full range available anywhere?
do they exist?
where do i find one?
would it be ok to run each voice coil off one side of a 'chip' amp, for stereo sound (yea not stereo but both channels would be heard through 1 driver... i think?)
ive built 2 nice boomboxes in the last 2 years using chip amps and full range drivers,
my new idea is to build something that has just 1 driver, can take full advantage of a chip amp (15wpc @ 4 ohms) is light as possible (easier to carry to the beach) and great sq
so i need a dual 4 ohm, dvc full range driver.
6", 8", 10" anything?
Old 5th May 2011, 01:57 AM   #2
sofaspud's Avatar
The only DVCs I'm aware of are subs. Why don't you just build a summing amp for a mono power amp input? Forget the exotic stuff. You can just tell the girls it's a rare audiophile DVC FR driver.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 5th May 2011, 02:35 AM   #3
2litre is offline 2litre  United States
Default Never tried one but...
Wouldn't this suite your requirements?
Dayton Audio ES80CS 8" Stereo Ceiling Speaker
No T/S info and 8ohm overall impedance.
R/
Old 5th May 2011, 03:44 AM   #4
build an amp? im pretty good with a shovel, soldering iron not so much.
R/
close but like you say, 8 ohm.
Old 5th May 2011, 04:04 AM   #5
sofaspud's Avatar
Hey, the shovel skills can be handy around here too!
You mentioned chip amps so I thought you were building from the ground up. A summing amp is just a simple op amp circuit. Super easy, even for a beginner. Don't sell yourself short. It may even be possible to do passively, with just a couple of resistors.
Old 5th May 2011, 04:45 AM   #6
41Hz Audio:Sounds Good to Me!
i could maybe do it, if i got a new soldering iron, and some helping hands, and a magnifying glass, etc etc..... maybe...
i can definitely buy one for about $70.
Old 5th May 2011, 05:03 AM   #7
sofaspud's Avatar
You can get a soldering iron at Walmart for ~$6. Good enough for learning. And some solder. The other stuff you don't need to do the job. Where's your DIY spirit, man!
Solder 2 10k resistors in series. Where they join is the input to your amp. The 2 ends are the L and R inputs from your signal source.
The op amp version isn't much more involved than that. It needs a power supply of course.
That's the extent of my arm-twisting.
Old 5th May 2011, 05:15 AM   #8
with a tip the size of m finger.
mdf.
hmm series, i wonder if thats across the +ve and negative or 2 together on the -ve?.... or positive?
Where they join
where what join?
spagetti or bbq?
The op amp
theres more then 1 kind of amp?
hmm power supply, you mean a battery right?
and thats the extent of my electronics knowledge,
i can build a killer horn loaded enclosure in about 4 hours tho
thanks for the nudge, but imma stick to what i know and let those that have been playing with electronics for a while build the amps.
Old 5th May 2011, 05:43 AM   #9
sofaspud's Avatar
Wow. I'm really at a loss after that reply...
You appear to have plenty of money, excuses, and line feeds. You don't need me.
Old 5th May 2011, 05:50 AM   #10
picowallspeaker's Avatar
It is just a matter of power delivered to each single coil (speaker) ,so in a efficiency/cost calculation an amplifier can cost as a coil (High AWG for lowpass ,doubled ) and active EQ can overcome system deficiencies . If horn enclosures and their size just don't matter ...the problem is solved !
Full range driver recomendation for dual mono LM3875 gainclone? zebra100 Full Range 5 4th August 2009 07:23 AM
16 Ohm Full-Range Speaker thelordash Chip Amps 13 23rd January 2009 05:13 PM
50W 4 ohm Full range suggestions revans Full Range 7 5th August 2008 03:24 PM
Dual Concentric a true full range??? torontodude Full Range 13 13th May 2007 03:14 PM
need help on info on DUAL type 260283 10" Full Range Coaxial (german made) eestrera Full Range 1 2nd November 2006 01:28 PM
Page generated in 0.12745 seconds (82.14% PHP - 17.86% MySQL) with 10 queries
