Can you make a decent enclosure out plastic or metal boxes? - Page 2 - diyAudio
Old 12th May 2011, 07:15 PM   #11
gfiandy is offline gfiandy  United Kingdom
gfiandy's Avatar
In answer to your specific question rather than getting into an idealistic rant over wood or other materials.
The plastic enclosure you have identified will make an OK speaker. It would be good to cross brace it to reduce the pannel vibration and add some damping material to the inner surfaces if you hear high frequency emphasis when you listen to the side of the box (keep the volume quite low when doing this). Retain the foam and use some of it to fill the enclosure this will reduce standing waves and increase bass slightly by reducing the speed of sound.
Will it make the best speaker in the world - No.
Will it be really quite good - if you use good drivers and don't expect it to play at 120dB then yes.
Andrew
Old 12th May 2011, 10:28 PM   #12
Alex from Oz's Avatar
Originally Posted by Ty_Bower View Post
There are those who would strongly argue, "No". Make sure you continue onward and read his article on lacquer as well.
Mother of Tone -The Mother of Tone
Interesting read, thanks for sharing this.
Hmmm, maybe time to 'spruce-up' my system.
Alex
FREE Marantz CD-50 SE metal-plastic chassis (CDM4 based) happycat Swap Meet 0 7th June 2009 02:34 PM
cutting metal/plastic sheets ?? kambule Everything Else 0 30th June 2006 10:58 PM
metal vs plastic transistors maylar Solid State 85 7th March 2005 06:44 PM
Copyright 1999-2017 diyAudio
