Are these coral flat 10's ok?
Old 2nd May 2011, 08:43 PM   #1
skvuppla is offline skvuppla  Denmark
Default Are these coral flat 10's ok?
I'm thinking of buying a pair of coral flat 10's, but are these OK? or are they too beaten-up?
Or is it just visual?
the asking price is 120$
Thanks for help
Old 3rd May 2011, 12:16 AM   #2
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Can't open the attachments.
planet10 needs your help:
Let's help Ruth and Dave
Old 3rd May 2011, 05:37 AM   #3
Sorry..
Here's new links
hope they work
Old 3rd May 2011, 07:53 AM   #4
Squeak is offline Squeak  Denmark
Squeak's Avatar
My thoughts:
I'd say don't buy. Even if they were technically ok now, someone who is that uncareful to make precious drivers look like that, doesn't deserve to sell.
What's more, you don't know what they have been subjected to otherwise. They might have periodic failures or damage that is so slight that ill effects will only show up after some time.
If you are anything like me, cosmetic damage like that, could also become a real eyesore over time, that will keep you from fully enjoying them.
Old 3rd May 2011, 11:18 AM   #5
grimmrok is offline grimmrok  Australia
Those drivers have had a hard time. Permanent creases on both surrounds and cones. I might be wrong but likely due to being well over-driven for extended periods. Water damage and who has a clue as to why the alu caps and whizzers look the way they do.
Save your money for something else.
Old 3rd May 2011, 11:51 AM   #6
Eric1110 is offline Eric1110  Canada
Can you go listen to them in person before buying?
I'm not that put off by the metal cap and damage to the tweeter cone. I'm actually more concerned about the folds in the upper and lower surround you see on the lower picture (second driver). How did those happen?
Overall, for a vintage Coral Flat 10, I wouldn't discount it yet.
Old 4th May 2011, 09:55 AM   #7
then_dude is offline then_dude  Belgium
indeed, i have corals flat 8, and i have cut out the metal cap: they sound much much much better then with,
you should watch out for the suspension: not the cracks as such, but it is treaded with some sticky stuff to keep it flexible, after years it drys out and the driver isn't capable of producing bass. So if you go to listen them, make shure they are in an enclosure, (even a paper box is good enough, that you can hear if they still produce enough bass. (to be honest: i don't think they will) and there is no consensus how to solve the problem of the hard vernis on the suspension);
Old 4th May 2011, 01:34 PM   #8
60ndown is offline 60ndown  United States
function>form
id pay with paypal, if there are any issues with them you can return them (or at least get your money back)
Old 4th May 2011, 09:38 PM   #9
DYNABLASTERTUNERS is offline DYNABLASTERTUNERS  Serbia
DYNABLASTERTUNERS's Avatar
Yes there is! Try Armor All(shiny spray) on the suspensions!
http://www.diyaudio.com/forums/full-...lat-8-a-6.html
some of my Designs www.dynablaster.deviantart.com/gallery
Are these coral flat 10's ok?Hide this!Advertise here!
Coral Flat 5 t/s ballsingtripp Full Range 17 15th November 2009 08:46 AM
Coral Flat 6 vs. FE167e ? nodiak Full Range 0 27th November 2006 10:09 PM
Coral Flat 10 albertli Full Range 16 3rd August 2006 03:07 PM
coral flat 8 fullrange then_dude Full Range 9 25th September 2005 11:33 PM
Coral Flat 6 question. steenoe Full Range 4 29th June 2005 02:58 PM
Copyright ©1999-2017 diyAudio
