Old 2nd May 2011, 02:30 PM   #1
60ndown is offline 60ndown  United States
Default 'bass blocker' to protect FR driver?
if 'audiofools' might have access to the volume dial, is it 'sacrilegious' to instal something to protect a FR driver from too much low frequency signal/and or volume and risk coloring / affecting the whole sound ?
or can i solder something (cap/resistor/iductor?) on the +ve lead to protect the driver?
what value/s?
Old 2nd May 2011, 02:55 PM   #2
Did it Himself
richie00boy's Avatar
You would put a capacitor in series, but it's not really an audiophile solution unless you run it a fair bit below resonance. Then it's not going to do a lot anyway, so swings and roundabouts...
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 2nd May 2011, 03:50 PM   #3
purplepeople's Avatar
How about an inductor in parallel?
:)ensen.
Those who claim to be making history are often the same ones repeating it.
Old 2nd May 2011, 05:20 PM   #4
chris661's Avatar
ensen.
No!
A decent inductor will have a DC resistance of less than 1ohm.
Putting that across an amplifier will cook most. It'll be very quiet through the speaker so you'll turn it up and then the smoke comes out.
Not good.
Use a PLLXO.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 2nd May 2011, 06:17 PM   #5
i love the www, i learn so much and save so much time and equipment.
thank you
Old 2nd May 2011, 07:05 PM   #6
Oops. I traded brevity for clarity and made the suggestion to avoid issues with capacitors in series.
What I was thinking something like an inverse BSC circuit. Normally the driver in series with an inductor and resistor that are paralleled with each other. Instead the inductor and resistor in series then paralleled with the driver.
:)ensen.
Old 2nd May 2011, 09:35 PM   #7
Did it Himself
Same effect as Chris said just not as severe. Makes little to no difference to sound coming from the speaker as it's just a parallel element.
Old 3rd May 2011, 10:42 AM   #8
Uncle Meat's Avatar
How about a fuse?
Old 3rd May 2011, 11:37 AM   #9
put a line-level passive high pass in front of your amp, it'll cost you from $3
Old 3rd May 2011, 12:35 PM   #10
norman bates's Avatar
they still make f-mods?
I remember seeing that they roll at 6db even though they advertise 12db.
Norman
Show us how you Protect your beloved MOSFET Driver IC Reactance Class D 0 19th April 2010 03:14 PM
Need Comments on FR Bass Reflex blip1882 Full Range 11 28th September 2005 05:48 AM
How to figure FR with bass boost? Dave Jones Multi-Way 35 7th June 2004 06:34 PM
Page generated in 0.11584 seconds (79.42% PHP - 20.58% MySQL) with 10 queries
